Engine overheating?
SCOTT RUE
  • 1999 DODGE DAKOTA
  • 3.9L
  • V6
  • MANUAL
  • 210,000 MILES
As I am driving car starts to get hot. Temperature gauge starts to move up. Slight coolant smell. Gauge goes almost to the top and then goes back. Gauge fluctuates from almost red to about halfway. Get to my destination and coolant on hood and a bit in on the engine. Have filled up coolant twice.
Please help
Monday, September 10th, 2018 AT 2:28 PM
  • 52,797 POSTS
Good evening.
You have a coolant leak. It is the reason for the coolant under the hood and the overheat.
You need to pressure test the system to find the leak. I would also replace the thermostat as well.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
https://www.2carpros.com/articles/radiator-pressure-test
Monday, September 10th, 2018 AT 4:34 PM
CANDI901
  • 1999 DODGE DAKOTA
  • 6 CYL
  • 105,000 MILES
Yesterday morning, the truck started fine. I put it in reverse and it died. Started back up and it was fine. On my way home from work last night, I tried to slow down at a stop light and the engine really revved up. I looked at the temp and it was coming close to overheating. I pulled over and shut it off in time. The RPM's had been going high prior to shifting so I'm not sure if it's related. I checked the transmission fluid. Fine. The oil was low. Added two quarts. However, I found green liquid between the fan blade and engine. What do you think? Cracked radiator? Antifreeze leak/low? Or water pump? I opened the metal cap on the radiator after it had cooled down but I'm not sure how much fluid should be in there. Help! Oh, one more thing. No check engine light came on.
Saturday, October 3rd, 2020 AT 12:48 PM (Merged)
2CARPRO JACK
  • 11,533 POSTS
The rpm's went up beacuse the coolant sensor cant read air. Have the system pressure tested to find the exact leak. Also have the thermostat replaced. Radiator should be full to the top (engine warmed up) and the recovery bottle needs the specified amount in it
GOOGLER316
  • 1999 DODGE DAKOTA
Engine Cooling problem
1999 Dodge Dakota 6 cyl Two Wheel Drive Automatic 114k miles
My truck has over 114,000 miles on it and it is over heating. I dont see any sign of leaks coming from the upper and lower hoses. I havent yet check the thermostat but it was replaced last year and it seems like I'm always having to fill up the coolant. I'm a mechanic just starting out and even went to a trade school in 2004 but I just dont have the experience to figure it out please help.
SATURNTECH9
  • 30,869 POSTS
So does it just over heat when it's low on coolant?Or does the over heating make it low on coolant?If it's loosing coolant then over heating I would pressure test the cooling system and look for leak's. Also pressure test the cap you can loose a lot of coolant from a bad cap. If you can't find the leak from a pressure test then add coolant dye.
SELDEEN
  • 1998 DODGE DAKOTA
  • V8
  • 4WD
  • 150,000 MILES
Coolant has been spilling out of engine (not sure from where) when parked after normal driving. Will not happen if I leave heater on, but will still run hot.
  • 108,320 POSTS
Hi:
It could be a few different things. Just so you know, when the heater is on, the heater core acts as a small radiator which helps cool the antifreeze. Regardless, the cheapest and easiest thing is to replace the thermostat. If that doesn't work, check the radiator for corrosion. It may need to be flushed or rodded out. Finally, can you tell where the coolant is leaking from?
These guides should help su fix it
and
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
and
https://www.2carpros.com/articles/car-is-leaking-coolant
Let me know what you find. And if you have any questions, let me know.
SELDEEN
I replaced the thermostat and flushed out system and it seemed to help some but after 15 to 20 min. Of highway driving it will begin to overheat again. Hasn't leaked coolant again, but it looked like it was coming from the bottom hose into the radiator.
  • 108,320 POSTS
Hi:
Is it still overheating?
Saturday, October 3rd, 2020 AT 12:49 PM (Merged)
SELDEEN
Yes, it's still overheating. I changed the thermostat and had it flushed out. It hasn't leaked coolant again but I've had to keep the heat on to prevent it from going above 210. I checked and it seems the leak from before was coming from the lower connection to the radiator. It takes 15-20 min for it to begin to overheat and I can keep it down if I run the heater on full blast. The radiator fan is running. I'm not sure how to check for the radiator itself to be plugged or corroded.
Thanks for your help,
Sam
  • 108,320 POSTS
Hi:
I want you to check something. When the vehicle is in the process of overheating, open the hood, with a light look, check the lower radiator hose. See if it is colapsing.
As far as the radiator, you will need to find a place near you that will boil or rod out the radiator. What happens is the coolant tubes clog from corrosion. As a result, the coolant doesn't circulate. Thus, the car overheats.
Let me know about the rad hose. Check the top hose too.
SELDEEN
HI:
haven't responded back to this problem due to freezing temperatures outside have made it impossible to work on truck.
The cold temporarily solved the problem but with warmer weather this past weekend the problem is back. Checked the hoses and they aren't collapsing. I'm guessing this means radiator is the problem? Also The check engine light came on while pulling into the drive way, gave a P0132 code (scanner said it was the governor pressure sensor voltage was to high). The truck seems to have very little power until 30-35mph although not much better after that. Has a severe leak of tranny fluid which I can't tell if it's a hose or the main seal. Could this leak be causing the problem? I read online that that code was an o2 issue. Not sure where to start.
  • 108,320 POSTS
If everything has already been replaced, either the radiator is the problem, the engine is out of time (which would cause it to run poorly), or you have a bad head gasket.
I would start by having the radiator tested.
MIKE CHAVEZ
  • 1998 DODGE DAKOTA
  • 4 CYL
  • MANUAL
  • 115,000 MILES
I was driving around 10 miles from home, when the truck suddenly overheated. I let it cool and was near a pond, so I used a plastic container to pour water on the radiator. After the radiator cooled and was full of water, I tried to restart the truck. It cranks over, but will not start.
BLUELIGHTNIN6
  • 16,542 POSTS
Never good idea to pour water onto a hot metal object (i.E. Radiator). It will cause the object to crack due to the hot metal and much cooler water instantly changing the hot metals temperature.
May have cylinder head or head gasket failed which resulted in overheating as well as low cylinder compression which can prevent engine from starting. Need to have compression check done.
KRIDGERD
  • 1998 DODGE DAKOTA
1998 Dodge Dakota V8 Four Wheel Drive Automatic 160k miles
I am experiencing overheating when truck is under load such as going up a hill. Its not boiling over but gets real hot. I have flushed the cooling system. The water pump shows no signs of fault. I am not loosing any coolant. THe hoses look good. The fan clutch appears to be OK. I changed the thermostat. It doesn't appear to be related to a head gasket. The truck has never overheated before. I checked the timing and it reads 15-17 degrees. What in the world do I do next?
Hi kridgerd, Welcome to 2carpros and TY for the donation.
Could be airlock in the system try bleeding it and also check the exhaust system for restriction, the radiator if its clogged and test the coolant temperature sensor. If everything here are okay -block and pressure test the cooling system
DELHOBBY
  • 1998 DODGE DAKOTA
  • V8
  • 4WD
  • 130,000 MILES
Hello, I have a problem, my 1998 dodge dakota is over heating. In August 2009 I had my transmission completely rebuilt (was shifting funny), when I got my truck back, the belt was sqeaking, and truck was getting hot, I replaced the belt, still squeaked and overheated, then I replaced the water pump, same problems, then I replaced the clutch on the fan, no more squeaks, but still overheats, so onto the thermostat, I replaced it, still over heats. I completely flush the coolant system every year, like wise I completely flushed again. Still I am overheating. Minus replacing the $400.00 radiator, I have done everything. My radiator shows a temperature of 260 at the top, 150 in the middle, and 250 at the bottom. The clutch only sees the middle so it the disengages. All problems came about after trans was rebuilt. Could the trans be loading me engine making it work harder. I am unemployed, have been for 3years now, I have little money, and limited transportation. I can't afford a donation. If I get this fixed I can get a job, then donate to your service. I live in the middle of nowhere, so transportation is a must. Please help.
  • 108,320 POSTS
It sounds like you have done everything correctly. I need you to check something. Start the engine and let it warm up. If it starts to overheat, check the radiator hoses and make sure neither one is collapsed.
Let me know what you find. Also, are you losing any coolant (could it be a bad headgasket?)
DELHOBBY
First thank you for the response. I have performed a CO2 test and found no leak head gasket leak, I'm not loosing any coolant, and all hoses are in great shape. With the radiator cap off and at idle I have no problem, but going down the road about 10 miles, I over heat. I have alot of mechanics ( with over 15 years expirence) i'm friends with and they are all scratching their head.
