1998 Chevy Silverado service engine soon light
HOTSHIELDS
  • 1998 CHEVROLET SILVERADO
  • V8
  • 107,000 MILES
Service engine soon. Comes on under load and motor shutters under heavy load. Then light comes on. Have replaced plugs, wires Dist cap and rotor. No luck
Do you
have the same problem?
Tuesday, September 9th, 2008 AT 5:01 PM
RHALL77
May be a possible injector plugged up. Do you know what code you have
Wednesday, September 10th, 2008 AT 10:43 AM
HOTSHIELDS
Hey thanks for the reply. Yea I got the code read at auto zone. Although it wasn't much help. It showed PO300 which means Random/multiple Cylinder Misfire Detected. I thought maybe coil but, then again fuel pressure? Could mean so many things. I was going to call the dealer and see if his costly scanner could be alittle bit more specific.
Wednesday, September 10th, 2008 AT 12:35 PM
Related Check Engine Light Content
Recommended Guides
