99 Malibu losing coolant
SOXFAN04072
  • 1999 CHEVROLET MALIBU
Help! My 99 Malibu (3.1 liter - 150k miles) is losing coolant. There are no apparent leaks and the temp guage is a little higher than normal, but not too much. I put coolant in last Sunday and my low coolant light came on again this morning.
Any ideas would be greatly appreciated!
Do you
have the same problem?
Saturday, August 4th, 2007 AT 5:26 PM
CLY
I would take a look at the Intake gaskets. Also look at the oil cap and make sure that it is not going inside the motor. If it is the oil cap will have nasty stuff on the bottom of it.
Cly
Saturday, August 4th, 2007 AT 7:14 PM
SERVICE WRITER
  • EXPERT
Cly is likely right on. The level is actually going down correct?
Tuesday, August 7th, 2007 AT 5:59 PM
SOXFAN04072
Thank you for the replys. Took it to the garage on Tuesday and it is the head gasket - told it would be about a $700 job - ouch!
Thank you again!
Thursday, August 9th, 2007 AT 4:49 PM
Recommended Guides
