No electrical?
LINDALOUS47
  • 2007 FORD TAURUS
  • 70,000 MILES
Stalled one time in summer pulled to side of road and there is no electrical why?
Sunday, September 4th, 2011 AT 1:11 AM
This could be a number of reasons but if there is no electrical power at all when you turn the key on then you either have an issue with the battery terminals, or a fuse issue.
This means we need to review the wiring diagrams below and check the fuses and for voltage coming from the battery.
Also, we are going to have to test the alternator just to be sure it is okay. Here is a guide that will help with this:
Here is a guide that will help with testing these fuses:
Please see the diagram below and let us know if you have questions and what you find. Thanks
Saturday, June 12th, 2021 AT 9:02 AM
LYNDAV
  • 2006 FORD TAURUS
  • 100,000 MILES
Pulling on the knobs for the trunk or the hood do not work. Power locks doe not work, so the car will not lock. Not sure what could it be. Any ideas?
Wednesday, July 28th, 2021 AT 2:02 PM (Merged)
CJ MEDEVAC
  • 11,004 POSTS
This sounds like a dead battery or a bad connection, either at the battery or the other ends where the battery cables connect to components.
Check out this guide I am linking you to:
Return with good news!
The Medic
JAUSTIN73
  • 2003 FORD TAURUS
  • 6 CYL
  • FWD
  • 82,170 MILES
Sitting at a stop light, foot on the brake, the vehicle just turned off. No power to anything, not even the "theft" light on the dash board. After pulling the keys out and then attempting to restart, some of the dash lights came back. When trying to start it up, the lights were intermittent and flickering quite a bit. I could hear solenoids or relays making clicking noises as well as what sounded like some sort of motor or pump trying to turn on back near the trunk, but nothing worked.
BMRFIXIT
  • 19,053 POSTS
It sounds like the battery cables are dirty here is a guid to help you get it fixed.
Cheers
BILL FLETT
  • 2002 FORD TAURUS
Pulled away from a stoplight the other night and the car died. Stopped the car, put it in park and cycled the ignition key and nothing happened. Had lights and accessories, but the engine wouldn't turn over. Tried it a few more times and no luck. Waited a few minutes and tried again and it started right up. Took the car straight home and parked it in the garage.
Went to use the car a couple of days later, went to the garage and started the car, then went in the house. Came back 10 minutes later and the car had died while I was inside. Cycled the ignition key -had all lights and accessories, but when the key is turned all the way, nothing happens. Cycled the key several times and finally got a connection and it started. I then shut it off and it hasn't started since -and boy I've been turning that key back and forth! Everything on the dash looks normal when you stick in the key and begin to turn it, but "seems" as if there's no electrical connection being made to engage the starting circuit. There's no sounds at all, not even a click from the engine.
I'm thinking the car has a bad ignition (solenoid? -The harness & apparatus on the steering column that plugs into the back of the ignition key housing?). After all I'm reading about on the various newsgroups I'm not sure if there's something else that may be interfering with the starting process. Any ideas?
Oh, by the way, the theft light is continuously flashing. I don't drive the car that much (my wife does) and I'm wondering if, once you use the electronic key to unlock the car, shouldn't the theft light go out?
Wednesday, July 28th, 2021 AT 2:03 PM (Merged)
PLHOUGHT
I dont mean to be simple, but have you checked your battery? Try giving it a jump-start or something (charge battery, try a newer one..etc) and see if that makes a difference.
As for the theft-light the low battery will cause that
Here is a guide to help you test it.
Patrick
BILL FLETT
The battery has better than 12 volts and I even tried a jump. Wouldn't even give me a click.
MIKEP
The description of this problem perfectly matched something that happened to our 2002 Taurus. After looking at about every exotic problem I could think of (Ifnition Switch, Lock, ad. Nauseum), it turned out to be the starter. I know this answer is long after the fact, but I hope it helps someone else.
Mike
