ABS light on and code C1300
CARL DREW
  • 2003 TOYOTA CAMRY
  • 3.0L
  • 6 CYL
  • 90,000 MILES
Have ABS light on. Scanned code C1300. What is the problem and Part
number and location of part?
Do you
have the same problem?
Tuesday, September 1st, 2020 AT 2:34 PM
  • EXPERT
Good morning,
I attached the flow chart for you below. Diagnostics need to be done to determine the failure.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Codes rarely identify bad parts, just a failed system
In a lot of cases, the module itself is the issue but needs to be confirmed with testing.
SKID CONTROL ECU ASSY
REPLACEMENT
1. REMOVE INSTRUMENT PANEL UNDER COVER SUB-ASSY NO. 1
2. REMOVE INSTRUMENT PANEL SUB-ASSY LOWER
3. REMOVE SKID CONTROL ECU ASSY
a. Remove the 2 nuts and disconnect the skid control ECU from the reinforcement.
b. Disconnect the skid control ECU connectors and remove the skid control ECU assy.
4. INSTALL SKID CONTROL ECU ASSY
a. Connect the skid control ECU connectors.
b. Install the skid control ECU to the reinforcement with the 2 nuts.
Torque: 5.5 Nm (56 kgf-cm, 49 inch lbs.)
5. INSTALL INSTRUMENT PANEL SUB-ASSY LOWER
6. INSTALL INSTRUMENT PANEL UNDER COVER SUB-ASSY NO. 1
7. PERFORM YAWRATE SENSOR ZERO POINT CALIBRATION (W/ VSC)
8. PERFORM DECELERATION SENSOR ZERO POINT CALIBRATION (W/ VSC)
9. CHECK VSC SENSOR SIGNAL (W/ VSC)
Wednesday, September 2nd, 2020 AT 6:10 AM
