ABS brake warning light on?
JAM SANI
  • 2012 TOYOTA CAMRY
  • 2.4L
  • 4 CYL
  • 62,000 MILES
Brakes okay. What is wrong with it? Please see video: https://youtu.be/e5BTGWyY4C0
Friday, November 6th, 2020 AT 9:10 AM
  • 52,797 POSTS
Good afternoon,
You have a failure in the ABS system. There is a fault code stored and that is the reason For the trac light as well.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
A parts store will read the code for free for you. Once you know the code, I can help track the area of failure. In a lot of cases, it is a wheel speed sensor.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Friday, November 6th, 2020 AT 11:41 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,046 POSTS
It sounds like you may have a wheel speed sensor that is out. These videos will help us find the problem:
https://youtu.be/rTtAnsOlZU4
and
https://youtu.be/Pb6nXV-iamI
and
https://youtu.be/ANWVTh2RQoQ
and
Wednesday, March 10th, 2021 AT 1:41 PM
LEEMAN SEBASTIAN
  • 2010 TOYOTA CAMRY
  • 168,558 MILES
I recently brought my car to an auto shop but they could not find the problem. They did a diagnose on my car but the mechanic said it could be a deeper issue and they do not have the stuff to do it. Apparently, there is something wrong the ABS. I found out that some inner coil is not connecting to the ground. I have a device that detected the "ABS Inlet Valve Circuit short to ground" and "a low battery positive voltage." Not sure the first one means but I have a feeling the next one might be the reason for the problem. I am sure you have come across some situation like this. Please help. Is it going to affect my car in the future? Like immediately or can I schedule another appointment to fix this problem? Your answer is much appreciated. Thank you.
Wednesday, March 10th, 2021 AT 1:42 PM (Merged)
KEN L
  • 43,046 POSTS
The first thing to do is check the charging system. Here is a guide to help you see what to do, also is this a hybrid?
It sounds like you may have a wheel speed sensor that is out. These videos will help us find the problem.
and
and
and
TKOMZY
  • 2009 TOYOTA CAMRY
  • 4 CYL
  • 170 MILES
Just today, the brake and the ABS light came on and off as I drives. But my brakes works perfectly and there is no leak according to a nearby mechanic. I just want to know if I should worry over this or I should not.
Thank you
  • 52,797 POSTS
Good afternoon.
You have a fault code in the ABS system. This system is separate from the normal brakes you have. The only thing is you do not have the protection of ABS in a panic stop situation.
Can you drive it, yes. I would not ignore it at all. I would have the system scanned for the failure and at least get an estimate of the repair.
TKOMZY
Thank you Sir for the reply.
How much do you think this might cost and where can I repair it?
  • 52,797 POSTS
Once you have the fault code read and you give me the code, I can give you a rough estimate.
You can go to a parts store and they will read it for you for free.
MUSTAFA ALTEMIMI
  • 9 POSTS
  • 2008 TOYOTA CAMRY
  • 2.4L
  • 4 CYL
  • 200,000 MILES
My problem is when the car is started, ABS light is off, with abnormal brake sound with shaky speedometer needle until the car reach 40 km/h.
The ABS light comes on, the brake doing fine and the speedometer needle doing well.
How can I fix this?
Thanks for help.
  • 52,797 POSTS
Good morning.
There is a code stored in the ABS module for a failure. We need that code to further track down the area of failure.
As far as abnormal braking, can you explain this further?
The speedometer issue does it stop working or is it just not consistent?
https://www.2carpros.com/articles/brake-system-warning-light-on
CARL DREW
  • 2003 TOYOTA CAMRY
  • 3.0L
  • 6 CYL
  • 90,000 MILES
Have ABS light on. Scanned code C1300. What is the problem and Part
number and location of part?
  • 52,797 POSTS
Good morning,
I attached the flow chart for you below. Diagnostics need to be done to determine the failure.
Codes rarely identify bad parts, just a failed system
In a lot of cases, the module itself is the issue but needs to be confirmed with testing.
SKID CONTROL ECU ASSY
REPLACEMENT
1. REMOVE INSTRUMENT PANEL UNDER COVER SUB-ASSY NO. 1
2. REMOVE INSTRUMENT PANEL SUB-ASSY LOWER
3. REMOVE SKID CONTROL ECU ASSY
a. Remove the 2 nuts and disconnect the skid control ECU from the reinforcement.
b. Disconnect the skid control ECU connectors and remove the skid control ECU assy.
4. INSTALL SKID CONTROL ECU ASSY
a. Connect the skid control ECU connectors.
b. Install the skid control ECU to the reinforcement with the 2 nuts.
Torque: 5.5 Nm (56 kgf-cm, 49 inch lbs.)
5. INSTALL INSTRUMENT PANEL SUB-ASSY LOWER
6. INSTALL INSTRUMENT PANEL UNDER COVER SUB-ASSY NO. 1
7. PERFORM YAWRATE SENSOR ZERO POINT CALIBRATION (W/ VSC)
8. PERFORM DECELERATION SENSOR ZERO POINT CALIBRATION (W/ VSC)
9. CHECK VSC SENSOR SIGNAL (W/ VSC)
IFEOYE
  • 2002 TOYOTA CAMRY
  • 4 CYL
  • 8,900 MILES
Good Day, please I want to know what causes ABS ligth to be on constant on CAMRY XLE and why does the engine oil keeps blinking occasionaly while drive. What is the cause of this? Thank you. Wil be expecting ur reply
MMPRINCE4000
  • 8,548 POSTS
The ABS light indicates a malfunction in ABS system, this can be a loose wheel sensor or ABS controller or may other things.
You will have to take to a garage that scans "C" (chassis) codes, which is what the ABS system will set if malfunctioning.
If oil level is full, then you most likely have a bad oil pressure sender, but could also be low oil presure.
Have a shop measure oil pressure with a mechanical gauge to verify.
Running an engine with low oil pressure can cause severe damage especially on Toyota engines.
MRIGGS
  • 2002 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 95,000 MILES
My father is the owner of the subject vehicle. He explained the problem as the anti-lock brake warning light first illuminating during a short drive and upon turning the vehicles ignition off the "anti-lock brake pump" continued to run. All fluid levels are normal and fuse eventually was removed to stop the "pump" from continuing to run. Unsure of how to address this problem other than taking the vehicle in to the dealer. Any advice is appreciated.
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
This means you have an anti-lock brake code or codes stored in you vehicles computer. This first thing I suggest is to retrieve the code information for us. Here is a video showing what is involved to retrieve anti- lock brake codes:
https://www.youtube.com/watch?v=rTtAnsOlZU4
Once you perform this, get back to us with the code information and we can then properly diagnose. Hope this helps and thanks for using 2CarPros.
2CP-ARCHIVES
  • 4,540 POSTS
  • 1993 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 75,000 MILES
1993 Camry mileage: 75,000. The ABS light stays on and the Toyota dealer told us it would cost about $1,800.00 to repair. Since the car is driven only by me and not used a lot, I would like to skip the repair. The car runs beautifully and the brakes work fine without the ABS. However, we were told we could not pass inspection with the ABS light on. Can we just disconnect the ABS without computer problems? Might the cost be less than $1,800.00 for repair? I learned more about my Camry reading all your other questions and answers.
Wednesday, March 10th, 2021 AT 1:44 PM (Merged)
2CP-ARCHIVES
  • 4,540 POSTS
We suggest that you get a second opinion from an independent service source. You may find that something as simple as a wheel sensor has failed which would be relatively inexpensive to repair. Question, did the Toyota dealer tell what part of the ABS system failed? Some parts are very expensive. We would never suggest that you disable the ABS system the system was designed to give you an extra margin of safety while braking.
LOMBARDI GRAHAM
  • 2007 TOYOTA CAMRY
  • 175,000 MILES
My car's ABS light and brake light comes and goes off and on my odometer bounces up and down and the AC starts to run warm when this happens happens. I changed the battery and the alternator is less than a year old. It happens then stops.
Thursday, March 11th, 2021 AT 12:35 PM (Merged)
  • 108,300 POSTS
Welcome to 2CarPros.
The first thing I would suggest is to scan the computer for diagnostic trouble codes. Often times that will point you in the right direction.
Here is a quick video showing how it is done:
https://youtu.be/YV3TRZwer8k
I realize that most people don't own a scanner, but often times a parts store will do it for free or lend/rent a scanner to you.
If you have no access, we need to do some basic testing. Anytime the brake and ABS go on and off, I first check to make sure the brake fluid is full. If it is low, it can cause both lights to come on.
Next, if it is full and no codes are found, we need to check the wheel speed sensors on the vehicle. One could be failing, have a corroded connection, or be damaged.
If you look at the first pic below, it shows the locations of a wheel speed sensors. To test them, you need to use some very basic testing equipment that most people have at home. First, here are the directions.
Here are a few links to help with checking:
If you find an issue with one of the sensors, here is a link that explains how in general one is replaced.
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
Here are the directions specific to your vehicle. The attached pics correlate with these directions.
REMOVAL
1. REMOVE FRONT WHEEL
2. REMOVE FRONT WHEEL OPENING EXTENSION PAD LH
3. REMOVE FRONT FENDER LINER
4. REMOVE FRONT SPEED SENSOR
pic 2
a. Disconnect the front speed sensor connector and clamp.
pic 3
b. Remove the 2 bolts from the body and the shock absorber assembly.
c. Disengage the 2 claws from the steering knuckle and body.
pic 4
d. Remove the bolt and the front speed sensor.
NOTE:
- Prevent foreign matter from attaching to the sensor tip.
- Clean the installation hole and the surface for the speed sensor every time the speed sensor is removed.
INSTALLATION
1. INSTALL FRONT SPEED SENSOR
pic 5
a. Install the front speed sensor with the bolt.
Torque: 8.0 N.m (82 kgf.cm, 71 in.lbf)
NOTE: Prevent foreign matter from attaching to the sensor tip.
pic 6
b. Install the front speed sensor with the 2 bolts and engage the 2 claws.
Torque:
Bolt A 5.0 N.m (51 kgf.cm, 44 in.lbf)
Bolt B 19 N.m (194 kgf.cm, 14 ft.lbf)
NOTE: Do not twist the wire harness for the front speed sensor when installing the speed sensor.
pic 7
c. Connect the front speed sensor connector and clamp.
2. INSTALL FRONT FENDER LINER
3. INSTALL FRONT WHEEL OPENING EXTENSION PAD LH
4. INSTALL FRONT WHEEL
Torque: 103 N.m (1,050 kgf.cm, 76 ft.lbf)
5. CHECK SPEED SENSOR SIGNAL
__________________________________
Now, if you find that one of the rear sensors is bad, the sensor is part of the hub assembly and will require the hub to be replaced. Here are the directions for that. Again, the attached pictures correlate with these directions. Note, the directions include checking the hub bearing which will not be relevant if the sensor is bad.
REAR AXLE HUB AND BEARING
COMPONENTS
pic 8
ON-VEHICLE INSPECTION
1. REMOVE REAR WHEEL
2. SEPARATE REAR DISC BRAKE CALIPER ASSEMBLY
3. REMOVE REAR DISC
pic 9
4. INSPECT REAR AXLE HUB BEARING LOOSENESS
(a) Using a dial indicator, check for looseness near the center of the axle hub.
Maximum: 0.05 mm (0.0020 inch)
NOTICE: Ensure that the dial indicator is set perpendicular to the measurement surface. If looseness exceeds the maximum, replace the axle hub assembly.
pic 10
5. INSPECT REAR AXLE HUB RUNOUT
(a) Using a dial indicator, check for runout on the surface of the axle hub outside the hub bolt.
Maximum: 0.07 mm (0.0027 inch)
NOTICE:
If runout exceeds the maximum, replace the axle hub assembly.
6. INSTALL REAR DISC
7. INSTALL REAR DISC BRAKE CALIPER ASSEMBLY
8. INSTALL REAR WHEEL
Torque: 103 Nm (1,050 kgf-cm, 76 ft. lbs.)
REMOVAL
HINT:
Use the same procedures for the RH side and LH side.
The procedures listed below are for the LH side.
3. REMOVE REAR DISC
4. REMOVE REAR AXLE HUB AND BEARING ASSEMBLY
(a) Disconnect the skid control sensor connector.
pic 11
(b) Remove the 4 bolts and hub and bearing assembly.
INSTALLATION
pic 12
1. INSTALL REAR AXLE HUB AND BEARING ASSEMBLY
(a) Install the hub and bearing assembly with the 4 bolts.
Torque: 80 Nm (816 kgf-cm, 59 ft. lbs.)
(b) Connect the skid control sensor connector.
NOTICE: Do not twist the sensor wire when connecting it.
2. INSPECT REAR AXLE HUB BEARING LOOSENESS
3. INSPECT REAR AXLE HUB RUNOUT
4. INSTALL REAR DISC
5. INSTALL REAR DISC BRAKE CALIPER ASSEMBLY
6. INSTALL REAR WHEEL
7. CHECK ABS SPEED SENSOR SIGNAL
_________________________________________
