Transmission, Only Drives In Reverse Gear?
All Forward Gears Are Zero Fluid Is Good Not Burnt. Was Driving Fine Then Nada.
Paul Summers
Stop At Red Light And Transmission Would Not Go Into...
No Lights No Leaks Just Wouldn't Go Into Gear. I Tried Shifting To All And No Movement. This Car Is Automatic Well Taken Care Of. I Was...
William bradley
HONDA CRV
Every Time It Shuts Off My Computer Data Is Lost?
Both The Check Engine Light, And Battery Light Come On, But Turn Off When I Turn On My Car Again. I Can't Seem To Pass Emissions, As...
justasking:)
MITSUBISHI ECLIPSE
Where Is The Camshaft Position Sensor Located?
I Can't Seem To Locate The Camshaft Position Sensor. Help
Loveysnwa
LINCOLN CONTINENTAL
Stalling When The Transmission Is In Reverse, And The...
I Was Pulling Out Of A Parking Spot At The Store And My Car Started To Get Really Wobbly And Ended Up Stalling. All The Lights On The...
TheGrifShot117
SUBARU FORESTER
Car Will Not Start When Hot?
The Car Listed Above Is A Super Beetle With Auto Stick. The Car Runs Flawlessly With No Issues Except, When The Engine Is Hot, 25 Mile Or...
dsmith1961
1974
VOLKSWAGEN BEETLE
95 Buick Century Need Lights For All
Have No Brake Lights No Headlights Radio Resets Anti Lock Light On Just Replaced Switch For Headlights. Still Same Problem.
Rachelle Donaldson
BUICK CENTURY
AM 2 Fuse Blows Very Time I Start The Car
Car Stop While Driving. The Next Day We Replace The Am2 Fuse (blue 15) And The Car Ran For About 15mins Then Died I Tried Replacing It...
Sabin c
TOYOTA ECHO
The Engine Shuts Off When The Transmission Is Shifted...
My Car Cranks Up But When You Put It In Drive It Automatically Cuts Off.
alexisfrazier00
Warning Lights
Mustang Threw Up A Door Ajar, Trunk Ajar, Parking Brake, Tire Pressure Sensor Fault, Advance Trac Fault Lights All At The Same Time. The...
Sah352
Door Ajar, Trunk Ajar, Parking Brake, Tire Pressure...
My Car Threw Up The Door Ajar, Trunk Ajar, Parking Brake, Tire Pressure Fault, And Advance Trac Fault Lights All At The Same Time As...
Sah352
Pin Code, Intermittently Not Starting Horn Blowing?
I Have A Lunch 431v Can’t Find Out Can't Find Out How To Get The Pin Code Can’t Find Out How To Get The Pin Code.
william927
Steering Angle Sensor Failure?
I Recently Had My Rack And Pinion/steering Gear Replaced Because It Had Failed And Was Leaking Power Steering Fluid. They Also Replaced My...
bendgall
HYUNDAI SANTA FE
Where Is The Camshaft Sensor Located?
It Cranks No Spark Rotor Is Turning.
wsking
FORD E-SERIES VAN
Are The Front Parking Lights Supposed To Work?
I Have The Vehicle Listed Above, 4 Door. The Front Turn Signals Were Flashing On Both Sides On Either Left Or Right Turns. I Don't...
Autoracingbear
1964
BUICK WILDCAT
There Is A Sound In The Rear Tires When I Turn Left Or...
My Vehicle Listed Above Does A Noise When Turning Left Or Right.
Eliuth
Crank No Start
I Was Driving And I Had Loss Of Power Then The Car Shut Off Completely And Has Not Turned On. When The Car Shut Off The Car Didn’t Let Me...
nick98568
BMW 328XI
There Was A Loss Of Power And Then Completely Shut Off...
My Car Had A Loss Of Power And Then Completely Shut Off. I Tried To Tow It, But The Car Would Not Shift Gears At All. I Had To Manually Get...
nick98568
16 IMAGES
BMW 328XI
Air Conditioner Works Intermittently?
It Goes From Very Cold To Hot, And Then Back To Being Cold. When The A/c Starts To Blow Warm, The Compressor Won’t Kick On. The High-...
ashleycox86
FORD EDGE
When Accelerating My A/C Seems To Quit Blowing, Why?
What Might My Problem Be?
James Monreal
Open Broken Rear Doors On Extended Cab?
When I Bought This Truck, Neither Of The Exterior Handles Opened The Rear Doors On The Extended Cab. Now Neither The Interior Nor Exterior...
Jacob Marino
Misfire?
No Codes On Scanner However, I Have A Light Misfire, Rapid Fire If I Kick It Down On A Hill. But It's There But Not Constant. Again...
My02Taurus
Drivers' Side A/C Is Much Warmer Than The...
I Have Been Troubleshooting My Driver Side A/c. So Far, I Have Replaced The Blend Door, However It Still Won’t Move. I’m Not Sure If...
Owardiv
Engine Blue Smoke After Engine Swap?
After I Changed The Motor For A Good Running One And After I Put It In My Car After Like One Hour Of Driving It Was Doing The Same Thing...
nik1234554
Where Is The Fuse For The A/C Compressor Clutch...
Can't Find A/c Clutch Fuse?
Joseph Pappagallo
NISSAN TITAN
599
600
601
