Low Rev At Idle And Other Little Problems.
Car Specs: Gold Iii Gl 4 Door '93. 117000 Km On It. It's Been About A Week That When The Engine Is Cold (im In Canada At -10...
phillyboy
Erratic Idle Problems 97 T-bird
Hello, I Have A 97 Ford Thunderbird 4.6l V8 With 133500 Miles, Last Week When I Cranked It Up, I Noticed That My Idle Was Behaving...
Heavnz_Warrior
1992 Jeep Wrangler
Hello Everyone, Today, When I Placed My 1992 Wrangler Into Part Time 4wd From Full Time 2wd, The Indictor Light On The Dash Panel Did...
ejm
JEEP WRANGLER
1998 Legacy Idle Control System Malfunction
:( I Just Purchased A 1998 Subaru Legacy Outback Limited. After 5 Days The Check Engine Light Came On. The Trouble Code Read 1507 And Shows...
Ginny
SUBARU OTHER
99 Ford Escort Stalling HELP!
I Have A 99 Ford Escort, 5-speed Which Has Been Taken Back And Fourth To Different Shops For About A Year Now. The Problem Is While Idling...
ianchreis
Please Help , Cab Fair Is Killin Me :{
Hi, Newbie Here. I Have A 1995 Altima That After About 7 Miles Of Driving Started Spittin N Sputterin, Blew Some Black Smoke Than Died. I...
skynswede
97 Dodge Intrepid Battery Light On
I Have A 1997 3.3l V6 Dodge Intrepid With 225,000 Miles. Recently The Interior Lights Started To Flicker And The Battery Light Came On. I...
gzechman
DODGE INTREPID
95 For Aerostar
I Have A 95 Ford Aerostar 105000 Miles. Recently I Have Noticed That At About 45 Miles An Hour There Is A Moderately Loud Humming Or...
einigue
FORD AEROSTAR
96 Cavalier Check Engine Light Comes On With Intake
I Have A 1996 Cavalier Z24 And I Bought An Aftermarket Short Ram Intake (ingen) For It; However, When I Put It In My Check Engine Light...
96cavalier
1997 - Chevy/Opel Blazer Turn Signal Problem
Issue: Left Interior Turn Indicator Light Stays Solid When Activated, As Do Both Left Exterior Turn Indicators. Right System Functions...
jyendall
2001 Dodge Intrepid Oil Light Will Flash When Hitting...
I'm New To This And A Little Freaked Out About My Engine Blowing Up. I Just Had An Oil Change And All Kinds Of Other Fluids Change Done Last...
justme
DODGE INTREPID
Overheating
97 Dodge Caravan Everytime I Stop At A Red Light For More Then 20 Seconds The Temp. Needle Goes Up To The H Once I Start Driving The...
cmb3210
CHRYSLER VAN
Mazda B-3000 Water Pump
I Was Wondering How Much It Would Cost Me To Replace My Water Pump. I Was In The Middle Of Replacing It When I Ran Out Of Knowledge.
Gemmett
MAZDA TRUCK
Unknown Problem
I Have An 85 Amc Eagle Limited. The Car When I Start It Cold Will Run Fine After Warming Up For About 15 Min Or So. Sometimes When I'm...
Thouago
EAGLE OTHER
No Go
I Have A 93 Lumina. It Idels Fine/ Reves Up Fine . Put It In Gear Give It Gas It Dies. Then It Wont Start. Unless I Hold The Gas To The...
tonebonemc
Re-looping The Serpentine Belt
I Was Hoping To Aquire A Diagram Or Picture Of The Proper Routing For The Serpentine Belt. To Clarify, I Mean The Belt That Powers The...
Carmar
96 Windstar, Heater Fan Only Works On High.
96 Windstar, Heater Fan Only Works On High. Any Help? Also, Once Last Summer, The Rear Hvac Would Blow Hot Air, When The Front Hvac Was...
sasngang
94 Astro Van Electrical Problems
Can You Still Check To See If The Alternator Is Bad By Disconnecting Battery While Engine Is Running?
slse4
91 Camaro Rs Clunks In Rear End Feel It Throughout The...
At 40mph And Up My Camaro Will Clunk In The Rear End And It Feels Like The Car Kinda Jerks When I Let Up Off The Gas. Changed U Joints...
91camaro
Help!!!!!! Please. Vortec Missing At Idle
I Have A 99 Ck1500 Vortec 350 W/68000 Miles. The Problem Shows Up When The Truck Is At An Idle It Codes In P306 Or Cyl. 6 Misfire. Im At...
chevyguy
1988 Mercury Tracer Crank Pulley
The Crank Shaft Pulley Bolts Broke And I Lost The Drive Pulley For The Ac Compressor And Power Steering Did Not Loss The Balancer I Do Not...
ridered38
MERCURY TRACER
Fuel Filter Location
My Father Recently Purchased A Toyota Truck, Can You Tell Me Where The Fuel Filter Is
PHOTOBOY7
TOYOTA PICKUP
1996 VW Golf - Won't Start
I Have A Vw Golf And Had Some Repairs Done, I.E, Replaced The Fan Belt, And Did A Tune-up, Lube Job And Had The Locks Fixed On The Doors...
penelope95546
KEY STUCK IN IGNITION
My Key Is Stuck In The Ignition. I Can't Turn The Key All The Way To The "0" Spot On The Ignition. The Steering Wheel Is Not Locked. It...
run800
VOLVO V70
Another Thermostat ??
? I Have A '98 Mazda 626 And Today While I Was Driving To Work, My Mazda Started Over-heating! I Have Never Had Trouble W/over-heating...
laflaca505
MAZDA 626
20216
20217
20218
