2000 Jeep Grand Cherokee Larado
In Wet Weather The Horn Blows Until You Remove The Fuse And Some Times The Cruise Control Acts Up, Once The Weather Changes Everything Is...
bos
Chrysler Intrepid 2001 - High-Pitched Noise
Just Bought An Intrepid With 80k And Drove Like A Dream For A Couple Weeks, Then It Turned Cold Here. Driving Along And Noticed That...
ajglitch
DODGE INTREPID
1999 Ford F-150 Performance Issue
This Guy That Supposedly Worked For A Ford Dealership Garage Said That There Is A Known Problem With The Butterflies Not Opening Properly...
sousadad
Dead Battery Charging System Possibly Caused By Stereo...
Long Story Short: [i:dfbba0c5f3]dead Battery Charging System Possibly Caused By Stereo Amps[/i:dfbba0c5f3] If You Think You Can Help: [i:...
goku87
Voyager 97 Clock & Radio Light
The Clock And Radio Light On My 97 Voyager Is Out Making It Impossible To See Radio Channels Or The Time. Any Thoughts? Thank You
Bethvoyager97
CHRYSLER GRAND VOYAGER
Die Out
I Have A 1981 Buick Regal And In The Mornings When I First Start Up My Car, It Starts Up Then Dies Out, And After I Get It Going, When I...
jmp210
1991 Toyota Tarago Problem
:( While Parking, The Aircondition Was Still On, And Realise That There Was Water Coming Underneath And Its Color Orange, Why Is This...
apineru
Car Stalls At Lights
I Have A 1993 Chevy Lumina 3.1l V6. When I Come To A Stop At A Light My Car Will Die. If I Shift Up Into Neutral And Play With The Gas The...
joyfull1979
Ride Control
1997 Lincoln Continental Indicates Check Ride Control. The Rear Of The Car Passenger Side Is Noticeably Now Lower Then The Driver Side. What...
sandoval
1997 Plymouth Voyager
I Have The Above Vehicle, When I Start It Up Every Morning I Have To Keep My Foot On Accelorator And Then Have To Keep Foot On Gas And Use...
kk3528
PLYMOUTH VOYAGER
Replacing Speed Sensor
Anyone Know Where The Speed Sensor Is On A 2000 Dakota? And How Hard It Is To Replace. And If It Can Cause The Brake/abs/tranny Light To...
wpbdakota
93 Isuzu Pickup Misses & Backfires
My Truck Just When It Hits Operating Temp And Then When You Slow Down Or Accelorate It Has No Power, It Will Sputter & Back Fire Smells Real...
bmpmoss
Spitting And Sputtering All Rpm Ranges
I Have A 93 Mercury Villager When Accel It Spits And Spudders Cked All Sensors For Proper Restence Ok Cked Fuel Presure Ok Could It Be That...
sissypoo1
FORD F-350
98 Cavalier Z-24 (Won't Start Or Turn)
My Car's Just Under 100k, And I Replaced The Battery About 4 Months Ago. I Turned The Car Off Today And When I Tried Using The Door Lock...
Kaminabe
Mazda 626 V6 2002
I Have Mazda 626 V6, 2002 Model With 70k Miles Approx. I Had Changed The Plugs That I Bought In September (about 65 K Miles) From Autozone...
ms_nadia
MAZDA 626
Dashboard Troubles
I Currently Own A 1996 Pontiac Grand Am With 87000 Miles On It. Recently, The Gauges On The Dashboard Have Malfunctioned. All Of Them...
CrazyChase
Parking Brake 1995 Pontiac Bonville
My Parking Brake Is Not Set But My Bell Is Going Off Like It Is And It Will Only Stop Every Now And Then Whenever I Hit My Regular Brake And...
JPardue
PONTIAC OTHER
84 240DL Dies After Running... Need Help ASAP
Hi, I Have A 1984 40 Dl Wagon / 4 Cyl Eng Plan Package. My Problem Is That After Running For A While The Lights Dim, And The Car Dies...
fndriver
1984
98 Protege Alternator Belt Major Problem
My Daughter Has A 98 Protege That I Have Had To A Mechanic Originally For A Squealing Noise When It Started Up. He Said It Was The...
Tennytaz
Pontiac Quad Four
I Have A 1996 Grand Am With 40000 Miles The Check Engine Light Came On With Fault Code P0420/p0304. Can The Coil Housing Be Causing This....
john savino
Power Steering High Pressure Hose Length And Shape
I Have Noticed On More Than One Make Of Automobile That The Power Steering High Pressure Hose Seems Longer Than Necessary And Has Some Odd...
J.D.
Bronco 2
My Bronco 2 Is Blowing Alot Of Carbon Out Of Exhaust When Rpms At 4000+ And Then She Runs Rough And Then She Will Run Good For A Short Min...
alansr
2000 Prizm.toy Stuck Head Bolts
I Have To Remove The Head From My 2000 Prizm 1.8 Vvt 140,000 Miles And The 3 Of The Head Bolts Would Not Budge. Used A New 10mm Hex And...
Applianceguy
Engine Oil Leak (1996 MERCEDES-BENZ C280) !
Hi There: I Am Buying A Used Car (1996 Mercedes-benz C280, 116,500 Mi). When I Took It To Firestone To Do A "vehicle Inspection", It...
cyberjags
MERCEDES BENZ OTHER
Headlight Problem With 03 Police Interceptor
I Have An 03 Police Interceptor. I Had A New Alternator Installed A Month Ago. About Two Weeks When I'm Driving I'll Hear A Vlick In The...
interceptorman
20204
20205
20206
