1997 Mercury Sable
RICH120865
  • 1997 MERCURY SABLE
Is blowing water droplets from tailpipe. Runs rough at idle or slow speeds. Check engine lite is on. Codes say 1 and 2 cylinder misfiring. Changed plugs. 1 had small amount of oil on it. I drove it over 100 miles on interstate when it started and it seemed ok until I got off and slowed. I let it run in park. Had to refill radiator after maybe an hour. It started to run hot but didn't get into "H" zone on gauge. Last month I had thermostat and water pump replaced. This may be unrelated but heater blows cold air even before I had thermostat replaced.
Do you
have the same problem?
Monday, January 23rd, 2006 AT 2:46 PM
JACK42
Have it chemical tested for a blown head gasket
Tuesday, January 24th, 2006 AT 4:23 PM
Recommended Guides
