Focus 2000 PCM Questions??
Hi, According To The Ford Dealership My Pcm (powertrain Control Module) On My 2000 Focus Is Shot. By Shot, I Mean When They Get No...
bobc
97 Cabrio Suddenly Accelerated By Itself
Yesterday I Was On The Highway Going 75mph. All Of A Sudden It Sped Up By Itself. First I Thought The Pedal Was Sticky, So I Pulled The...
Cabrio ler
No Spark?
I Have A 1979 Ford Falcon 302, The Problem Started When I Was Driving And The Car Lost Power, I Pulled It Over And It Started Fine. I Got...
dodgey_69
1979
Intake Gasket Leak
I Own A Nissan Altima 01 With 30k Miles On It. Recently, I Noticed Some Issue With The Car When It Started Jumping Between The Gears And...
sanjayv
Voyager Floods While Driving
I Have An 87 Voyager 3l V6 I Just Changed Brain Box And Put In Plugs, Dist. Cap, Rotor And I Took Out The Oxy Sensor And Cleaned It.I...
Caravan
CHRYSLER GRAND VOYAGER
91 Pontiac Sunbird Died On The Freeway
1991 Pontiac Sunbird - 2.0l L4 Engine, Mileage 160,000: I Was On The Freeway Doing 65 Mph Last Night, When Traffic Slowed. When It Picked...
mikel
PONTIAC SUNBIRD
Intermittent Crank Issue
Hi, Thanks For Having Me At This Forum. I Hope Somebody Can Help. My 88 Toyota Pickup Is Having Intermittent Starter Issues. After A...
timbo3366
TOYOTA PICKUP
Nissan Sentra 2001
Hi Nissan Sentra 2001, 150k Manual 5sp Transmission. When I'm Slowing Down And I Press The Clutch Especially When I Go From 3rd Gear To...
sentraman
Avs Joint Repairquestion
Http://cgi.ebay.com/ebaymotors/94-97-d-s-honda-accord-new-cv-drive-shaft-...
kjones
Cars Seems To "give" Under Applied Load.
Not Sure If This Is Clutch Issue Or Someother. The Car Seemed To "flutter"and Kinda Buck When I Shifted From 1 To 2 In Low Rpm. Then...
tofkrew
HONDA OTHER
Car Not Turning On...after Testing Max Speed
Hi. I Drive A 2005 Ford Focus Se. I Was On An Open Country Road Today And For The First Time Decided To Test It Max Speed. After I Reached...
rae87
#3 Misfire On 01 Focus ZX3
Ok The Problem Started All Of The Sudden One Day. The Night Before The Car Was Fine Then I Start It Up The Next Day And It Ran Like Crap....
USAF_AMMO
I Have Pinging Noise Under Hood Of My 94 Isuzu Rodeo
I Went To Get Pinging Noise Checked Out And I Was Told That I Have Maybe A Piece Of Carbin In Between Piston And Shaft. And I Was Told To...
tonysky7
Heater Noises
I Have An 84 Full Size Bronco, 351w. The Heater Makes An Awful "growl" Or Deep "squeal" When Its Running. There Is Warm Air Coming Out...
jknaughton
Fuel Reset Button?
Our Explorer Will Crank But Not Turn Over. We Were Told About A Fuel Reset Button, But Do Not Have A Manual And Do Not Know Where It Is...
jncfranck
Rear Wheels
When Driving Slow And Hitting Bumps I Heard A Popping Noise In Rear. I Got Out And When Pushing Wheels On Top You Hear Them Hit Metal. (...
chuckee
1999 Dodge Durango Electrical Problem
I Have A 1999 Dodge Durango That Isnt Charging The Battery. When You Get The Car Started It Runs For A Few Min And Then Dash Lights Start...
scottn83
DODGE DURANGO
1994 Eagle Talon
I've Run Across A Problem I Have Not Seen Before. My Talon Runs Fine When The Engine Is Cold, But As It Reaches Optimum Running Temperature...
Julie Fadoir
EAGLE TALON
Cavalier Struts
I Have A 95' Cavalier Z24, And Whenever I Make A Left Turn There Is A Cracking Noise Coming From My Front Wheel Well. I Was Wondering If...
Moments4mourning
Engine Swap ?
I Need Some Info From A Real Ford Motor Head. I Have My 86 Ford Bronco Ii And It Has A 2.9l V-6 Fuel Inj, I Have Gotten Ahold Of A 302 Small...
Paul75
1998 Dodge Caravan
I Am Having A Probelm With My 98 Grand Caravan, 144,000. The Brake Lights Are Not Working. I Honestly Have No Clue How Long They Havent...
dodgelover
Changing Spark Plugs 2001 Rodeo
Before I Break Something, Can You Help Me With How To Locate And Remove The Spark Plugs From My 2001 Isuzu Rodeo? I Have A New Set Of Six...
kruzoo
Repair Manual
Do You Know Where I Can Find A Repair Manual For A 1997 Kia Sportage?
cgertken
KIA OTHER
AMIGO 2.6 OIL LEAK
I Have A 1993 Amigo 2.6 With Oil Leaking From The Right Side Of Engine. Replaced Front Crank Seal. Oil Press. Sender Not Leaking. Looks...
RONNIE
Cylinder 1 Missfire
Code Reads P0301 Cylinder 1 Missfire Ford Said They Dont See Nothing Wrong, Still Having The Problem!
superhuman777
20180
20181
20182
