Speedo Sensor
I Have A 96 Civic Ls, My Oil Fill Cap Came Off And Shot Oil All Over The Engine, I Replaced And Refilled My Oil And Have No Problems With...
benthesp
HOW TO ADJUS/CHECK TPS
1992 Buick Lesabre 165k Miles 3.8l Auto Trans Need To Adjust Throttle Position Sensor, Also Can't Find Map Sensor Have Codes Of 22, 26, 34...
Arthur Barnes
1994 Ranger 4.0 L Serpentine Belt Installation
I Ahve A 1994 Ranger 4.0 L And Want To Change My Own Serpentine Belt, But I Can't Understand How To Take The Tension Off The Belt...
pzaremba
Volvo XC90 Diesel (D5) 2003 HARD START
I Bought My Volvo 3 Months Ago Second Hand With 105000 Km. It Is Common Rail Diesel. From The Begining I Bought It, The Motor Starts Harder...
spetrov
VOLVO XC90
1994 Geo Metro
Where Is The Ecm Located On The 1994 Geo Metro?
Metro Mech
1999 Chevy Silverado Brakes Not Adjusting...
A Buddy & I Did A Shade-tree Replacement Of The Rear Brake Pads. Should Be No Problem, Done Other Vehicles Before - No Sweat. A Day...
WSC48
AUTOMATIC TRANSMISSION FLUID LEAK
My Wife Has A 1996 Ford Tarus 3.0 V-6. It Leaks Transmission Fluid But Not All The Time? Yesterday, You Could See Where It Had Leaked On...
DINGALANG
Trouble Starting Diesil
I Have A 1999 Ford 350 Deisil Dually With 177,000 Miles On It. What Makes It Not Start Even On A 60 Or 70 Degree Day Unless Its Plugged...
saintcin
FORD F-350
1990 Pontiac Transport Head Gasket
I Have A 1990 Pontiac Transport With 130,000 Miles And The Exhaust Is Is Leaking Into The Coolant Meaning I Have To Replace My Head Gasket....
elj1979
PONTIAC TRANSPORT
Radiator Antifreeze In Gas Tank
My Son Ran Out Of Gas In His Saturn Lat Night, A Passerby Told Him It Was Safte To Put Radiator Antifreeze In His Gas Tank To Get Him To...
concerned dad
Engine Hard To Start
I Have A 90 Mercury Grand Marquis With 96,000 Miles That Is Hard To Start. It Will Turn Over But Wont Fire. It Will Start With Starting...
dwright
2001 Toyota Rav 4 140,000mi
My Engine Light Has Been On For A Couple Months, In Need Of A Fuel/air Ratio Sensor According To The Code, But The Car Has Acted Fine...
josher
Turns But No Go,HEEELP!!!
I Have A 94 Chevy Impala Ss With 145000 Miles. I Changed A Bad Water Pump And Ever Since It Will Not Start. It Started Fine Before I Got...
94impalaSS
1996 Grand Caravan 3.3
I've Disconnected The Power Steering Pump For Replacement Now How Do You Get It Out?
jonone
Knocking Sound Coming From Engine
I Have A 2002 Honda Civic Ex Coupe. It Has 25,000 Miles On It. It's A Good Car But Recently I Have Been Having This Problem With It -...
allanc
1997 Thunderbird - Strong Reapeted Knocks - Rear Left
I Have A 1997 Ford Thunderbird With 139,000 Miles. I Have The Most Annoying Problem I Ever Had With A Car. Every Time I Accelerate Above 50...
yoav739
FORD THUNDERBIRD
OIL PRESSURE LIGHT
Please Help Us. We Have A 1998 Dodge Intrepid With 168400 Miles On It. We Just Purchased It Used And Changed The Oil After We Got It....
SADEHE
DODGE INTREPID
88 Honda Prelude 180000mi
The Car Is Not Charging, The Alternator Is Getting Power To It But None Coming Out. But When I Had The Alternator Tested On A Load Tester...
gravie
HONDA PRELUDE
Is My Flywheel On Backwards
My Tourque Converter Is Grinding Against The Atf Pump Houseing
heidi petersen
1989 GMC Jimmy
I Have A 1989 Gmc Jimmy And The Fuel Pump Is Out And I Need Step By Step Instructions On How To Change It Asap. Thanx
memers_6
GMC JIMMY
Need Help With '97 Ford Ranger Dome Light.
My Dome Light In My 1997 Ford Ranger Xlt Reg Cab Has Just Recently Started Acting Up. It Sometimes Wont Turn Off Right Away (like A Delay...
unfblah
Clicking Noise In The Engine
I Have A 1990 Ford Ranger, Mileage 170,000:it Has A 2.9 Fuel Injected Engine: My Question Is Whenever I Start My Truck There Is A Clicking...
atvmattmiller17
Knock From Rear End
2002 325i Sedan Very Strange Situation. Sounded Like I Had Something Rolling Around In The Trunk, Crashing Against The Walls. Then, I...
stanj
BMW 325
How Do I Get The Rotor Off Of A 1994 Ford F150 4x4
I Took Off Wheel And Outside Hub And Can't Get Rotor And Front Of Hub Off
regghook
1995 Oldsomobile Cutless Supeme Ls
Today I Got In My Car I Begin To Drive I Noticed It Didnt Feel As If It At The Boost As It Normally Does I Didnt Shut It Off For Atleast 30...
jaime
20126
20127
20128
