No Spark, Just Cranks?
Changed Fuel Pumps, Crank Shaft Sensor, Checked Ignition, Changed Spark Plugs And Qualpack Checked Starter, Fuse #10(starter) Is Pulsing...
Dean 3131
DODGE CALIBER
No Crank No Start No Power At Instrument Cluster?
Had A Fuel Problem Which Turned Out To Be The Tipm, So I Replaced It With One From A Salvage Yard. Same Thing Happened So I Returned It And...
bill.leroux
Change The Rear Main And Oil Pan Gasket?
Does Anyone Have A Link To A Video For My Specific Model On How To Change The Rear Main And Oil Pan Gasket? I Can't Seem To Find One....
Tankk2014
O2 Sensor Faults When Throttle Is Applied?
I Have A 2017 Ford Focus And We’ve Had Our History, Replaced A Clutch, Catalytic Converter, And Other Things. I Truly Love This Car...
Tmreger2022
Control Module Replacement And Location
I Bought A Control Module From Another 2016 Cadillac Srx And Im Going To Install It In Mine And Need To Know Where The Location Is And If...
Scott Picklesimer
CADILLAC SRX
C0074 Error Code
Recently, My Car Needed A Jump Start, And I Found The Battery Voltage Was Low. I Replaced The Battery And Also Changed The Brake Pads At...
vetmohit89
SUBARU OUTBACK
Any Update On Image Posting?
Seems To Be Still Down Across The Site. Multiple Posts That Require Images.
Steve W.
Blend Door Actuator Number And Location(s)?
Are There More Than One Blend Door Actuators In A 2008 Kia Sorento, One For Passenger, One For Driver?
ryanheart93
KIA SORENTO
How To Reprogram Car Key Fob For Keyless Entry Remote...
When I Got The Car I Had 2 Fobs, One I Use Every Day And A Spare. (The Spare Never Worked Though As Keyless Entry). I Lost The Original...
Yellowraccoonpanda
P1290 Code Faulty Coolant Temperature Sensor?
Looks Like It Threw A Code For A Faulty Coolant Temperature Sensor. I Cannot Seem To Locate Where The Sensor Is. Where Is The Sensor Located...
SwampyPete
Need New Bolts For Intake Manifold?
In Replacing Intake Manifold Gskt Do I Need New Bolts For Manifold And Am I Going To Have To Remove Valve Covers. And Throttle Body. Just...
Rwaddlesee
CHEVROLET VENTURE
TPMS Wont Reset?
Tpms Wont Reset?
NAZEER.K
VOLKSWAGEN POLO
Bank 1 Camshaft Position Sensor?
Where Is The Cps Located. I Have Already Replaced The Bank 2 Cps. I Cannot Find Where The Cps For Bank 1
benny13
LINCOLN NAVIGATOR
Turn The Key No Click And No Crank Radio Don't...
Went To Get Into Start The Vehicle And Everything Worked All The Way Up Until I Turn The Key And There Was Like A Pop Sound. The Radio Don...
Tatman1972
CHRYSLER SEBRING
Light On The Switch Flashing Between 2 Wheel And 4...
Chevy Tahoe Will Not Drive Four-wheel Drive Light Flashing Between Two Wheel Drive And Four-wheel Drive Will Not Move Anywhere
Adamreed
3rd Row Power Seats
Needing Wiring Diagram For The 3rd Row Power Seats. I Want To Instal The Seats And Switches.
Shawnwolfe
3rd Row Seats Wiring Diagram?
I Need A Wiring Diagram For The 3rd Row Power Seats So I Can Install The Power Seats.
Shawnwolfe
All Gears Gone?
No Forewarning. No Problems Or Clues At All Prior. It Was Running Great. All Fluids Checked And Good Before I Left. Driving Down The Highway...
PRD
TCCM Like A Grounding Issue??
I'm Chasing A Problem With My 1996 Tahoe (1500 4wd 5.7l) It's A Z71 If That Makes A Difference. There Are A Few Symptoms That Are...
slothomatic
Fuel Trims And Hesitation After New Cats?
My Car Developed Nissan's Infamous Cat Rattle About 2 Months Ago (the Substrate Breaks Into Pieces And Sounds Like Rocks In A Tin Can)...
Bill Marshall
INFINITI G37
Front Suspension, Arms, Struds, Disk, Caliper
2010 Nissan Note Manual Transmission 1.5 Dci Front Suspension, Brake Disk And Caliper And All The Arms Holders Etc. Related Nuts And Bolts...
Ghosty32
NISSAN NOTE
Cylinder 3 Misfire And Trac Control Light On
Jus Tbought The Car Cylinder 3 M, Isfire And Traction Light Coming On Reducing The Engine Power And Making The Miss Worse New Coils And...
natetoon76
Check Engine Light Code Was P2A01?
Hello, The C.E. Light Was On In My Vehicle And A Local Parts Store Checked It And The Code Was P2a01 Signaling An O2 Sensor Issue. ...
RPJ
CHEVROLET AVEO
Testing?
Making Sure This Is Working?
RPJ
CHEVROLET AVEO
Leaking Radiator Hole Or Crack?
Yes I’m Trying To Figure Out If We Have A Hole Or Crack In My Sons Radiator Or If The Guy From The Shop (that Was Supposed To Fix The Ac)...
BigRog
NISSAN VERSA
12
13
14
20253
