Gear range sensor - Neutral safety switch
EWFLETC
  • 2008 DODGE CARAVAN
  • 4.0L
  • V6
  • FWD
  • 84,700 MILES
For over a year now, I have had intermittent start problems on my 2008 Dodge Grand Caravan SXT 4.0L. I replaced the starter (no difference). The WIN module was recently replaced too and did not make any difference. From the research I have done, it sounds like the neutral safety switch is the issue. When the van does not start, I move the gear shift into Neutral and it starts right up. I am trying to find out how to replace the neutral safety switch.
Thursday, October 22nd, 2015 AT 11:54 AM
  • 110,101 POSTS
On this vehicle, the neutral safety switch is referred to as a transmission range sensor. It is located on the driver's side front of the transmission. I found the attached pic online to help you identify it.
Saturday, April 20th, 2019 AT 11:59 AM
CASTI523
  • 2004 DODGE CARAVAN
  • 3.3L
  • V6
  • 155,629 MILES
The reverse light does not turn on, they told me it was the neutral switch and I need to know the position and how to install it.
Friday, May 21st, 2021 AT 2:46 PM (Merged)
Good afternoon,
The back up light switch is part of the neutral switch. It is located on the valve body. The valve body has to be removed to access the switch.
I posted the information below and some pictures for you.
TRANSMISSION RANGE SENSOR
REMOVAL
1. Remove valve body assembly from transaxle.
ImageOpen In New TabZoom/Print
2. Remove transmission range sensor retaining screw and remove sensor from valve body (Fig. 305).
3. Remove TRS from manual shaft.
INSTALLATION
1. Install Transmission Range Sensor (TRS) to the valve body and torque retaining screw (Fig. 305) to 5 Nm (45 inch lbs.).
2. Install valve body to transaxle.
VALVE BODY
REMOVAL
NOTE: If valve body is replaced or reconditioned, the TCM Quick Learn Procedure must be performed.
1. Disconnect battery negative cable.
2. Disconnect gearshift cable from manual valve lever.
3. Remove manual valve lever from manual shaft.
4. Raise vehicle on hoist.
5. Remove oil pan bolts (Fig. 307).
6. Remove oil pan (Fig. 308).
7. Remove oil filter (Fig. 309).
8. Remove the valve body-to-transaxle case bolts (Fig. 310).
NOTE: To ease removal of the valve body, turn the manual valve lever fully clockwise to low or first gear.
9. Remove park rod rollers from guide bracket and remove valve body from transaxle (Fig. 311) (Fig. 312).
CAUTION: The valve body manual shaft pilot may distort and bind the manual valve if the valve body is mishandled or dropped.
KEITH FERRIER
  • 2003 DODGE CARAVAN
  • 3.8L
  • V6
  • FWD
  • 110,000 MILES
My van wont crank. When I turn my key the accessory relay clicks and that is it. Everything lights, radio, windows, etc work. As the key is turned I do not have any power to little wire on starter. If I bypass the ignition relay it turns over but the fuel pump is not coming on and I have no spark. I replaced the crank sensor and the ignition module on the steering column. Neither helped. I have check all the fuses and relays. All the wires under the dash looks good. Would the neutral safety switch cut power to the starter?
WRENCHTECH
  • 20,761 POSTS
Yes it would, the neutral safety switch or gear selector range sensor is located on the transmission here is a diagrams to help you see the location
Cheers
KEITH FERRIER
That was the problem thank you so much for the information all fixed. I love this site.
WRENCHTECH
  • 20,761 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers
2CP-ARCHIVES
  • 4,540 POSTS
  • 2000 DODGE CARAVAN
  • 270,000 MILES
Where is the neutral safety switch located on a 3 speed auto transmission? A diagram would be helpful.
Front of the trans under the car. It has 3 wires and screws into the case. Get the new one and match it up.
See the image below
DENNISGALEN
  • 3.3L
  • 6 CYL
  • 89,000 MILES
After replacing neutral safety switch it won't start in park but will start in neutral the reverse light on gear indicator is showing it's in reverse but the shift handle is in park?
Friday, May 21st, 2021 AT 2:47 PM (Merged)
Good morning,
The shift cable may be out of adjustment.
i attached the procedure for the adjustment below. Adjust the cable and see if it will start in park.
If the park neutral switch does not send a signal to the ECM for park position, it will not allow starting.
https://www.youtube.com/watch?v=QNSM3hRP6jk
Lift and rotate the gearshift hand lever into the park (P) gate position and remove the ignition key This confirms the shift lever is in the gated park (P) position.
After confirming the park gate position, turn the ignition switch. If the starter will operate, the park gate position is correct. Move the shift lever into the neutral (N) position. If the starter will operate in this position, the linkage is properly adjusted. If the starter fails to operate in either position, linkage adjustment is required.
(1)Park the vehicle on level ground and set the parking brake.
(2)Place the gearshift lever in park (P) gate position and remove key.
Fig. 38
(3)Loosen the cable adjustment screw at the transaxle operating lever (Fig. 38).
(4)Pull the transaxle operating lever fully forward to the park detent position.
(5)Release the park brake, then rock the vehicle to assure it is in park lock. Reset the park brake.
(6)Tighten the cable adjustment screw to 8 Nm (70 inch lbs.). Gearshift cable should now be properly adjusted.
(7)Check adjustment by using the preceding procedure.
JEFF GLASCOCK
  • 1999 DODGE CARAVAN
  • 3.3L
  • 6 CYL
  • 237,000 MILES
When trying to start van will not crank. Has full electrical power. Only fuel pump sound and relays clicking sound heard when turning key to start. After about fifteen of trying to start, it will finally start. Turn van off and try to start again and same deal. Have replaced the starter and key lock cylinder and ignition switch. Could it be the Transmission Range Sensor/Neutral safety switch? Where is it located on my van and how would you replace it? Thanks
  • 110,101 POSTS
Yes, the neutral safety/range sensor switch can cause a no start. However, usually they usually do not start working after they have failed. Try to see if the engine starts in neutral rather than park. If it does, then my first suspect would be the safety/ranger sensor switch. However, often times it is something as simple as a corroded or loose battery terminal or bad ground to the engine block. Take a look at this link:
Also, here is a link that discusses why a starter may fail.
The range sensor is located in the front of the transmission down low. See the attached picture. Basically, it unscrews from the transmission. Here is a link that shows in general how to check one:
https://www.2carpros.com/articles/how-a-neutral-safety-switch-works
RFREEMAN
  • 1997 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 250,000 MILES
I have a 97 van recently changed speed sensors now giving prndl switch slack. When changing prior sensors had to get for 02 so tranney has been changed. Where is the neutral switch
BMRFIXIT
  • 19,053 POSTS
https://www.2carpros.com/forum/automotive_pictures/99387_caravan_tranny_11.jpg
newer model
https://www.2carpros.com/forum/automotive_pictures/99387_caravan_tranny_05_3.jpg
