Fuse panel?
MARCHAZ84
  • 2004 TOYOTA CAMRY
Where is the power window fuse?
Monday, April 11th, 2011 AT 9:31 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,895 POSTS
I have found the fuse (power1) in the passenger fuse panel and the fuse box diagram (BELOW) and location for you so you can get the problem fixed. Here is a guide to help you change the fuse as well.
Thursday, June 1st, 2017 AT 5:31 PM
  • 52,797 POSTS
There is a 7.5 amp gauge fuse that feeds the relay and a 30 amp circuit breaker that controls the windows.
Check the diagram I sent you.
Thursday, June 1st, 2017 AT 5:32 PM (Merged)
JNOVACK
  • 723 POSTS
Check passanger side under dash above kick panel that is were the relay is located
TYLERTE
  • 1998 TOYOTA CAMRY
  • 150,000 MILES
My toyotas window fuse(30a) keeps blowing everytime I try to put a new one in any suggestions? And another thing I recently upgraded my speaker system and at first it worked fine but I took a ride and half way through they stopped working and its because the new amp blew a fuse does anyone think those two problems are connected in some way? Where should I check?
KHLOW2008
  • 41,815 POSTS
If the amp is spliced into the same circuit, they would be related.
