1991 Toyota Camry Fuel Filter
HBHAWKMAN
  • 1991 TOYOTA CAMRY
Engine Performance problem
1991 Toyota Camry 4 cyl Two Wheel Drive Automatic
what tools do I need to replace fuel filter?
Do you
have the same problem?
Thursday, August 26th, 2010 AT 11:49 AM
Just the basic tools see below:
REMOVAL:
Locate the fuel filter on the lower LH side of the engine compartment.
EFI Fuel Filter
http://www.2carpros.com/forum/automotive_pictures/12900_ff1_7.gif
If vehicle has been operated within an hour, the fuel system is probably under pressure and requires caution when removing filter union bolts.
Slowly loosen the filter union bolts. Some gasoline may escape, so ensure that the potential for fire is minimized.
EFI Fuel Filter
http://www.2carpros.com/forum/automotive_pictures/12900_ff2_2.gif
Remove the union bolts and four gaskets.
Loosen filter clamp and slip filter from clamp.
INSTALLATION:
Slip new filter into clamp. Ensure that flow arrows are in the correct direction.
Position filter in the middle of the clamp and tighten filter clamp.
Reinstall both union bolts with four new gaskets.
Torque union bolts to 13 ft.lbs. (18 N-m). DO NOT overtighten union bolts.
Clean any gasoline that may have escaped.
Start the engine and check for fuel leaks.
http://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Thursday, August 26th, 2010 AT 7:24 PM
Recommended Guides
