No communication with the ABS module
EL SURDO ALANIS
  • 2017 CHEVROLET SILVERADO
  • 6.6L
  • TURBO
  • 4WD
  • MANUAL
  • 44,000 MILES
My ABS light came on. Took my truck so they can put the computer to see what was the problem. The computer has no communication with the ABS module. How can I check if there is power on the module and it has enough ground source? Thank you
Saturday, December 29th, 2018 AT 11:10 AM
Good afternoon,
The first thing I would check is the powers to the ABS module. if you have powers to the module, good chance the module is bad. I attached a diagram for you to view and a video that show the module being replaced.
https://youtu.be/lUotkKXG9dY
Check out the diagrams (Below). Please let us know what you find.
Sunday, December 30th, 2018 AT 1:56 PM
MARCUS BISHOP
  • 2006 CHEVROLET SILVERADO
  • 5.3L
  • V8
  • 232,000 MILES
My front brakes randomly lock up. Changed master brake cylinder, both tire sensors, and it is still doing the same thing. Thinking now it is either the calipers or the module. Leaning more so towards the module because when the brakes lock up both sides (front only) lock up. If it was bad calipers only one side would lock up (whichever caliper was bad) Also, sometimes the truck shakes extremely bad when driving and stopping, as if a wheel is about to fall off. Then yesterday it drove smooth as silk with no issues. I have been dealing with the random brake issue for a week now. My question is: I watched your YouTube video on how to change the module, but I read somewhere else that I would have to bleed my brake system if I swapped the module. In your video you did not say anything about it, so would I need to or not? Also, do you even think it is my brake module?
Tuesday, February 23rd, 2021 AT 9:15 AM (Merged)
  • 110,149 POSTS
Hi and thanks for using 2CarPros. Com.
If you are only replacing the module, you are not getting into the hydraulics, so no. Here are the directions for replacement. The attached pictures correlate with these directions.
_____________________
Electronic Brake Control Module Replacement
Removal Procedure
Caution: Refer to Battery Disconnect Caution in Service Precaution.
Important: After installation, calibrate the new electronic brake control module (EBCM) to the tire size that is appropriate to the vehicle.
1. Disconnect the negative battery cable.
2. Raise and suitably support the vehicle.
3. Important: The area around the electric hydraulic control unit (EHCU) MUST be free from loose dirt to prevent contamination of disassembled ABS components.
Thoroughly wash all contaminants from around the EHCU.
4. Remove the mounting screws (1) that fasten the EBCM (2) to the brake pressure modulator valve (BPMV) (3).
5. Remove the EBCM from the BPMV. Removal may require a light amount of force.
6. Remove the EBCM from the vehicle.
7. Clean the BPMV to EBCM mounting surfaces with a clean cloth.
Installation Procedure
1. Important:
Do not reuse the old mounting screws. Always install new mounting screws with the new EBCM.
Do not use RTV or any other type of sealant on the EBCM gasket or mating surfaces.
Install the EBCM to the BPMV.
2. Notice: Refer to Fastener Notice in Service Precautions.
Install the new EBCM screws (1).
Tighten the screws to 5 Nm (39 inch lbs.) In an X-pattern.
3. Lower the vehicle.
4. Connect the negative battery cable.
5. If a new EBCM was installed, the EBCM must be programmed.
6. Turn the ignition to the ON position. DO NOT start the engine.
7. Perform the Diagnostic System Check
_______________________________________________
I hope this helps. Let me know if you have other questions.
AUSTINHELMS10
  • 5.3L
  • V8
  • 4WD
  • 234,000 MILES
I’ve tried removing the 4 torx bolts to remove it so you could match it to another module. But one of the back torx bolts seems to be stripped out and I can’t get anything to it. Please help!
Good morning,
You will need to get a sharp chisel and a hammer and try to knock the bolt loose in the counterclockwise direction.
If that does not work, you will need to cut the head off and remove the bolt after the module is removed.
https://www.2carpros.com/articles/how-to-replace-a-abs-controller
AUSTINHELMS10
The gap between the module and under the cab is not much. Are you sure this is possible?
You will have to remove the bracket and hydraulic unit together and perform this on the bench if there is not enough room.
Can you post some pictures for me? I would like to see what you see.
ROSENHAGEN
  • 2003 CHEVROLET SILVERADO
  • 5.3L
  • V8
  • 4WD
  • 150,000 MILES
I have a z71 1500ls Silverado and can't get the abs module out due to no room for a small rachet.
Tuesday, February 23rd, 2021 AT 9:16 AM (Merged)
HMAC300
  • 48,601 POSTS
The bracket that mounts the abs unit to the frame. Check out the diagrams (Below). Please let us know what happens.
YAHWEH
  • 2001 CHEVROLET SILVERADO
  • V8
  • 67,000 MILES
This unit continuely runs even when the ignition is off. What precedures or matenance must I take before I take my truck in for service. And is there option to take of this problem. What tools would I need to use that would really help.
DENNYP
  • 1,824 POSTS
The ABS control module needs to be replaced. To get it to shut off, look for the large ABS fuse in the underhood fuse panel. Remove the fuse. You can remove the module from the hydraulic unit without removing any brake lines. You will need a torx bit (I think it's a T-15 or T-20). Remove the torx screws from the top of the module and lift the module off of the hydraulic unit. Put on the new module, bolt it down, and re-install the fuse.
DENNYP
  • 1,824 POSTS
XTooltipElement
Service Information
2001 Chevrolet Chevy K Silverado - 4WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Brakes | Antilock Brake System | Repair Instructions | Document ID: 720110
Removal Procedure
Important: After installation, calibrate the new EBCM to the tire size that is appropriate to the vehicle.
Caution: Unless directed otherwise, the ignition and start switch must be in the OFF or LOCK position, and all electrical loads must be OFF before servicing any electrical component. Disconnect the negative battery cable to prevent an electrical spark should a tool or equipment come in contact with an exposed electrical terminal. Failure to follow these precautions may result in personal injury and/or damage to the vehicle or its components.
Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Important: The area around the EHCU MUST be free from loose dirt to prevent contamination of disassembled ABS components.
Thoroughly wash all contaminants from around the EHCU (1).
Disconnect the electrical connectors from the EBCM.
Loosen or remove the bolts (4) securing the EHCU mounting bracket (3) to the frame rail (5).
Gently move the EHCU down enough to remove the mounting screws that fasten the EBCM (2) to the BPMV (1).
Remove the EBCM (2) from the BPMV (1). Removal may require a light amount of force.
Important: Do not use a tool to pry the EBCM or the BPMV. Excessive force will damage the EBCM.
Important:
"� Do not reuse the old mounting screws. Always install new mounting screws with the new EBCM.
"� Do not use RTV or any other type of sealant on the EBCM gasket or mating surfaces.
Install the EBCM (2) on to the BPMV (1).
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the new screws in the EBCM (2).
Tighten
Tighten the screws to 5 N � m (39 lb in) in an X-pattern.
Install or tighten the EHCU bracket mounting bolts (4).
Tighten
Tighten the EHCU bracket mounting bolts to 25 N � m (18 lb ft).
Connect the electrical connectors to the EBCM.
Lower the vehicle.
Revise the tire calibration using the Scan Tool Tire Size Calibration function.
Return to Diagnostic Starting Point - Antilock Brake System .
© 2008 General Motors Corporation. All rights reserved.
https://www.2carpros.com/forum/automotive_pictures/102900_379478_1.jpg
https://www.2carpros.com/forum/automotive_pictures/102900_379484_1.jpg
RICHIE D
  • V8
  • 4WD
  • 90,000 MILES
The Motor associated with the ABS system keeps running after I shut off the engine, remove the key and exit the truck. ( It is under the truck with 4 hydraulic lines attached.) The only way to stop it from running, short of disconnecting the battery, is to remove the 60 amp fuse. I suspect that a relay is bad and stuck in the "On" position. What else could cause it to keep running? What relay should I check
/ repl;ace?
Any Ideas appreciated
Richie D
SWILLIAMS
  • 597 POSTS
Common failure on the Kelsey Hayes ABS unit. There is a control relay inside the unit that fails ON. The only real solution is to replace the ABS pump with a different one. You can buy NEW or you can get a rebuilt unit that has an upgraded part. Your choice. OR if you don't care if the ABS works you can pull the ABS fuse and ignore the light.
This video will show you how to fix it
KENTUCKYCUB
  • 5.3L
  • V8
I have the (4) bolts out of the Module What is the best way to get the two apart without prying?
HMAC300
  • 48,601 POSTS
Here is a video of the job being done
KENTUCKYCUB
I have already got the (4)bolts out, issue is how to get the EBCM apart from the EHCU without prying, would using a razor knife to cut the seal be practical
HMAC300
  • 48,601 POSTS
If you have cleaned around it then try using a rubber mallet or similar and tapping around it lightly to remove it.
KENTUCKYCUB
Thanks Hmac300 I got it, I was a little hesitant about hammering around on it, thanks for your help.
DALE KL
  • 3.8L
  • V8
  • 4WD
  • 140,123 MILES
On the ABS box, the bleeder valve is leaks. Is there a cheap way to fix?
