Window wiring?
STXHAMMER
  • 2002 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 172,000 MILES
Hey, I have the SUV listed above four door and the power windows won’t work at all. I pulled back the wiring harness boot and found a few cut wires. I’d like to either splice or solder the wires but unsure which wires do what. I’ve been trying to find a wiring harness diagram also. Thanks for any help.
Monday, May 4th, 2020 AT 7:36 AM
  • 52,797 POSTS
Good afternoon,
You need to peel back the covers and match up the wiring colors one at a time.
You need to solder and shrink wrap the wires. That will make a great connection and then wrap the wiring bundle in electrical tape.
I attached the diagrams with the wire colors for the windows and door locks.
Monday, May 4th, 2020 AT 10:51 AM
TOMMYLAKE
  • 1994 FORD EXPLORER
  • 4WD
  • 180,000 MILES
I need a wiring diagram for the driver side door master controller for windows locks and mirrors on SUV listed above Limited model.
Wednesday, October 7th, 2020 AT 11:25 AM (Merged)
  • 52,797 POSTS
Good evening.
Attached is the diagram you requested. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
