Powertrain light intermittently turns on while driving
RIAAN SNYMAN
  • 2016 FORD RANGER
  • 3.2L
  • 5 CYL
  • TURBO
  • MANUAL
  • 246,900 MILES
My truck's powertrain light comes on sometimes when I drive, but I am not losing any power and my temperature stays normal. It only comes on when the car is quite cool or getting wind at higher speeds. If I turn of the ignition and back on the light is gone.
Tuesday, October 20th, 2020 AT 11:26 PM
  • 52,797 POSTS
Good morning,
The ECM sees a fault stored when you first start it. I need that code to help you.
This video will show you what to do
https://youtu.be/InIlnsjOVFA
and
or
You can go to a parts store and have it checked for free. Once you get the code, post it here and I can help narrow the are of failure.
Wednesday, October 21st, 2020 AT 4:22 AM
REBECCA SOCHA
  • 2014 FORD RANGER
  • 5,000 MILES
Powertrain light on dash board.
Friday, November 27th, 2020 AT 9:40 AM (Merged)
  • 52,797 POSTS
Good morning,
This light indicates a fault code is stored in the computer.
The code needs to be identified, diagnostics performed and repairs made to get the light to turn off.
If you go to a parts store, you can have the code read for free. Once we know the code, we can help you with possible failures.
RUDESTAN
  • 2014 FORD RANGER
  • 3.2L
  • 5 CYL
  • TURBO
  • 4WD
  • 200 MILES
I drove today and noticed my powertrain warning light lit on my dashboard.
When I arrived home, I turned off the engine and restart it 2 hours later, no light. I am afraid to drive it before I know the problem. Any help is appreciated
Stan
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,895 POSTS
Hey RUDESTAN
The drive train light is telling you have a problem with the transfer case or transmission. The same as a check engine light scan the PCM for trouble codes, if the car is running okay it is probably safe to drive so don't worry there. Here are a couple of guide that will help us get started getting the codes.
and
https://www.2carpros.com/articles/check-engine-light-is-it-safe-to-drive
It sounds like a transmission shaft speed sensor problem but I want to be sure.
Please let us know happens so it will help others.
Best, Ken
BOBBYG22
  • 0 POST
I'm glad I found this, but I wish it was a little sooner I just got back from the garage for the tunes of $290.00 and right here is says what the problem is. The sensor is only $56.00 next time I will use 2Carpros
MICHAEL JORDAN
  • 2013 FORD RANGER
  • 2.2L
  • 41,000 MILES
Loss of power and a wheezing sound. What does this mean and what is the problem?
HMAC300
  • 48,601 POSTS
It sounds like you may have a vacuum leak. Here are two guides that will help us find the problem.
and
ROOSTER2
  • 2013 FORD RANGER
  • 2.2L
  • 4 CYL
  • TURBO
  • 187,675 MILES
Power-train warning lamp comes on after traveling about 10 Klm. Stop turn engine off start again then travel about 30 Klm then light comes back on.
Friday, November 27th, 2020 AT 9:42 AM (Merged)
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
This means you have trouble codes (check engine light) stored in your vehicles computer. You say the power-train light keeps flashing? First thing I suggest is to have the code(s) checked.If you don't have access to a scanner/code reader your local auto parts stores have a tool loaner program and can rent you one.Here is a tutorial showing what is involved:
Once you have the codes please get back to us with the code numbers and we will be happy to help properly diagnose your vehicle.Hope this helps and thanks for using 2CarPros.
Danny-
