We've had this car since Feb. 2007 and have had 6 rack & pinion systems installed to date. 3 genuine GM (including the one that came on it) and 3 after market provided. Is there a possibility that the installer, a GM dealership mechanic service could be doing something wrong with their installation? Do you have any other tips for a solution?
SPONSORED LINKS
Sunday, October 17th, 2010 AT 5:07 PM
WRENCHTECH
MECHANIC
I guess anything is possible. If the first rack came apart internally it could have contaminated the system with debris. Without proper flushing and maybe even a filter on the return line you could cause damage to another rack if installed. You may even have a pump that is failing internally causing the problems
What exactly is happening to these racks?
Read the guide below, it may help you figure this one out
2002 Gran Prix I R and R the rack. Now I can't run or route the hose from the pump to the rack. And I can't connect the intermidate shaft to the rack. All fittings are not lining up, they just keep spinning.I need diagrams.
Wednesday, November 14th, 2018 AT 5:54 PM
(Merged)
JDL
MECHANIC
I can't see much from here, exploded view below, hope it helps.
Images (Click to make bigger)
(Merged)
JDL
MECHANIC
If you saying the threaded fittings don't match, maybe you got the wrong rack, or your trying to thread the supply into the return or vise-versa.
(Merged)
MICHAELJTOMCHUCK
MEMBER
Diagram didn't help, I was hoping for your experence, Again that hose has too many bends and angles. Thank-you I took the rack out and tried the fitting and it worked. Right rack right fitting.I think that the rack is too high making it impossible to properly line up the hose to the rack.
SPONSORED LINKS
(Merged)
JDL
MECHANIC
Sorry man, I'm 64, can't remember every vehicle I ever worked on. I guess I'd have to look at it. Did you try to hook up lines before you bolted the rack down? Where applicable, can you lower the cradle just a little?
(Merged)
JDL
MECHANIC
Take the lines loose at the other end, connect to rack end, first.
(Merged)
NDTOOTALL66
MEMBER
1 POST
2004 PONTIAC GRAND PRIX
6 CYL
2WD
AUTOMATIC
130,000 MILES
I am going to replace the rack & pinion on my 2004 Pontiac Grand Prix GT2 When I look up the part there is 2 styles one w/ magnasteer and one without How do I tell which one I have Also How hard is it to change and what is the best way to bleed the lines once I replace it
(Merged)
MMPRINCE4000
MECHANIC
Dealer can tell you which you have, either through VIN, or "service parts identification" label.
Crank engine (do not start) with return hose disconnected to bleed syetem.
(Merged)
JDL
MECHANIC
Maybe with a tubing bender, you can nudge it, just a little?
(Merged)
DOOB
MEMBER
The rpo sticker is in the spare tire tub in trunk.
Tuesday, May 4th, 2021 AT 8:15 PM
MECHANIC
Thank you for the information. I'm sure it will be helpful to others.
