Overheating
SWEETS2580
  • 2006 DODGE MAGNUM
  • 2.7L
  • V6
  • 177 MILES
Hello, my car is overheating, I have changed the thermostat and hose. It only stays cool when I run the heat. Should I stop using half and half coolant and I pouring water in there as well? Should I use straight coolant no water added?
Do you
have the same problem?
Saturday, May 7th, 2016 AT 5:33 PM
  • EXPERT
Need to investigate other things first, it sounds like an air flow problem, make sure that the cooling fans are working, there is no rubbish built up between the radiator and the air conditioner condenser blocking air flow, and the radiator is flowing and not pat blocked, this is hard to tell with out removing and having it core cleaned by a radiator specialist.
Saturday, May 7th, 2016 AT 6:13 PM
Recommended Guides
