Will not crank over
2002 OLDSMOBILE SILHOUETTE
20,000 MILES
NSTAM
Van will not crank over. Can you help?
Jan 25, 2015 at 8:57 AM
SATURNTECH9
  • CAR REPAIR CONTRIBUTOR
  • 30,869 POSTS
It sounds like you have a dead battery but if the headlight are bright when you crank it over I would think the starter is out. To be sure here is a guide to help you test to confirm the issue:
Cheers
Jan 25, 2015 at 9:06 AM
MUNICH1984
  • 0 POST
I had this problem the shop replaced the starter cost me $230.00. All fixed!
Aug 25, 2018 at 6:19 PM
2CP-ARCHIVES
  • 4,540 POSTS
Difficulty starting. After driving vehicle, turn off for a short time, try to restart. Turns over but does not start. Some times my wife turns key over and it will start. Saturday night it happened to me. Turned over but would not start. Turned key over, same. battery drained. Came back about four hours later and it started right away. I am stumped for an answer. Thank's for your help.
Aug 25, 2018 at 6:19 PM (Merged)
HMAC300
  • 48,601 POSTS
Scan for codes and check fuel pressure first. If no codes and fuel pump is okay then check crank/cam sensors for high resistance.
https://youtu.be/YV3TRZwer8k
RAIDERFAN10
My van starts fine when cold but after running for a while it does not start easily. Engine turns over well so I do not think its battery related. It sounds like not all cylinders are firing because it stumbles up to idle rpm and rolls over and shuts off. I have to wait about fifteen to thirty minutes before I can start the engine. I have replaced fuel filter. Still same problem. Van has 84,000 miles with original plugs and wires. Someone suggested the fuel pump could be the issue or dirty fuel lines. Any ideas?
  • 110,190 POSTS
Hi.
First, if the wires and plugs are original, I would perform a tune up. Also, the fuel pump could be an issue. What I recommend is to perform a fuel pump pressure test on it. Here is a "How To" video that will explain how to do it and what to look for.
https://www.2carpros.com/dia/test_fuel_pressure.htm
Many parts stores will rent or lend a gauge to you or you can purchase one at the test equipment store site on this page.
Finally, has the check engine light ever come on and does the temperature gauge work properly in the car?
