Neutral safety switch
KEITH FERRIER
  • 2003 DODGE CARAVAN
  • 3.8L
  • V6
  • FWD
  • 110,000 MILES
My van wont crank. When I turn my key the accessory relay clicks and that is it. Everything lights, radio, windows, etc work. As the key is turned I do not have any power to little wire on starter. If I bypass the ignition relay it turns over but the fuel pump is not coming on and I have no spark. I replaced the crank sensor and the ignition module on the steering column. Neither helped. I have check all the fuses and relays. All the wires under the dash looks good. Would the neutral safety switch cut power to the starter?
Do you
have the same problem?
Friday, September 2nd, 2016 AT 7:45 PM
WRENCHTECH
  • EXPERT
Yes it would, the neutral safety switch or gear selector range sensor is located on the transmission here is a diagrams to help you see the location
Cheers
Saturday, September 3rd, 2016 AT 5:25 AM
KEITH FERRIER
That was the problem thank you so much for the information all fixed. I love this site.
Saturday, September 3rd, 2016 AT 8:04 AM
WRENCHTECH
  • EXPERT
Good to hear, please use 2CarPros anytime we are here to help.
Cheers
Saturday, September 3rd, 2016 AT 8:13 AM
Recommended Guides
