Engine will not crank over
TOMMYWRIGHT
  • 2006 MAZDA 6
  • 2.3L
  • 4 CYL
  • MANUAL
  • 200,000 MILES
Car will not start, new and verified good battery. At first, security light flashed repeatedly. Shorted both positive and negative battery cables together for approximately one hour. Reconnected battery and was able to start the engine twice, seemed like the engine would have continued to run if I allowed it. Came back at a later time, and the car would not start. Shorting the battery cables seemed to clear any immobilizer issues, until I turned the key to start. I no longer get the rapid flashing of the security indicator, but lose all electrical power. I performed these processes with both keys independently, but failed to get the engine to start. BTY, poser is restored by shorting the battery cables for a period. Any body have a suggestion to where to look next?
Tuesday, November 7th, 2017 AT 11:08 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,904 POSTS
It sounds like you have a bad connection at the battery.
Here is a guide to help you confirm the problem:
Cheers, Ken
Wednesday, November 8th, 2017 AT 12:36 PM
TOMMYWRIGHT
Ken, the battery is new. Terminals are squeaky clean. I have even had it checked at Advanced Auto. I certain this problem exists with he immobilizing system. I actually got it started after shorting the two battery cables after someone suggested that the immobilizer circuit utilized a magnetic switch. At that time I though it was fix, but reoccurred the following day. All electrical is good after resetting the circuit by shorting the two battery cables together. I get head lights, interior lights etc. Once I turn the ignition switch to start, everything shuts down, dashboard goes nuts, and of course, no solenoid or starter action.
One thing to note: I can push start the car!
TW
Wednesday, November 8th, 2017 AT 12:44 PM
KEN L
  • 42,904 POSTS
It sounds like the engine is not turning (cranking) over correct? The starter sounds like it might be shorted out or you have a positive battery cable that is bad. Please remove the cable and inspect it. Here is a guide so you can check to see if the trigger wire of the starter is getting power. Check toward the bottom of the guide.
and
You will need to raise the car up safely.
Please let us know what you find.
Cheers, Ken
Wednesday, November 8th, 2017 AT 7:39 PM
TOMMYWRIGHT
Ken, thanks for the help! I was convinced it was not a power problem, but I did as you suggested and inspected the positive battery cable. I found corrosion one the wire. I removed the terminal and soaked the cable ends ion a solution of water and baking soda all night Then wire brushed the exposed copper. Reassembled the battery calble to the terminal. Starts perfectly every time!
Thanks again
Tommy W.
Tuesday, November 14th, 2017 AT 7:04 AM
KEN L
  • 42,904 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Cheers, Ken
Tuesday, November 14th, 2017 AT 9:58 AM
JOHN FAVALORO
  • 2006 MAZDA 6
Engine Mechanical problem
2006 Mazda 6 6 cyl Two Wheel Drive Automatic
my car battery will come on and so will the radio and everything connected to the battery. The problem I am having is that my engine wont turn over it seems. Somone told me to beat on the starter but I have no idea where that is. Holla at me asap
Tuesday, November 14th, 2017 AT 11:38 AM (Merged)
  • 31,938 POSTS
Hi there,
This is just a way of UN sticking a starter if it is binding up and not a sure fire way of starting the car, if you have a starter problem, get it inspected and repaired don't mess around with these short cuts, it will get you nowhere.
Mark (mhpautos)
STEVEK85
  • 2007 MAZDA 6
  • 4 CYL
  • FWD
  • MANUAL
  • 39,000 MILES
Electrical problem
2007 Mazda 6 4 cyl Front Wheel Drive Manual 39000 miles
I was listening to the radio without the car running for about 15 minutes. When I went to start it, It was dead. All I heard was clicking. I may have also smelled something inside the car. I left it for a couple hours and when I tried again, it was slow to turn over but it started. I noticed that the only remaining problem while driving was that the passenger side window would not work from either door control. Also the automatic roll feature on the driver side window would not work even though it will roll down when I hold the button. All other windows work.
The positive battery cable connection had heavy corrosion. I cleaned it and found that, of the two strips wrapped around the terminal, one had broken. I put on a new terminal connection. After running the engine for minutes, my car will start again immediately without a problem but if it sits for 30 minutes or so, it will turn over slowly again. Can you narrow down what might be wrong please?
Tuesday, November 14th, 2017 AT 11:39 AM (Merged)
  • 108,200 POSTS
First, I would recommend taking the car to a nationally recognized parts store and have the battery load tested. If the battery passes the test, I would then check to see if there is a draw on the battery. Here is a how to for checking:
https://www.2carpros.com/first_things/why_is_my_car_battery_dead_over_night.htm
Let me know what you find. Chances are the battery is getting weak or there is a draw on it.
STEVEK85
It was a bad battery. They said the meter wasn't even sensing a conection between terminals. The car is only 2.5 years old. Could the connection corrosion have caused it to die an early death? Thanks for the help.
  • 108,200 POSTS
Corrosion can cause a bad connection, but the battery will usually last. I think you just got a bad one because the OEM batteries usually last a good 4 to 5 years.
Regardless, I'm glad you're up and running again. Let us know if you have questions in the future, and thanks for using 2carpros. Com.
BOBBY CLARKE
  • 2007 MAZDA 6
  • 75,000 MILES
The car will not start and the light inside the car want work and the radio will not come on like its has a lock down alarm mode
HMAC300
  • 48,601 POSTS
Check for blown fuses in main box on inner fender and relay
TANYA LYNN
  • 2004 MAZDA 6
  • 2.3L
  • 4 CYL
  • FWD
  • 214,000 MILES
The car wont turn over when the key is turned. The code reader says U0100.
The inside lights work.
WRENCHTECH
  • 20,757 POSTS
That is a communication code so one of the modules is not communicating at all. You will need a professional level scan tool to access the other modules to see which one is dead.
SEXYLADYKRISTI84
  • 2003 MAZDA 6
  • 140,000 MILES
It ran just fine and I came home from work and when I went back out to try and crank it, it turned over with just a whinding sound but wouldnt crank. I checked the oil and it was bone dry! It had just had a oil change 3 weeks ago. So I wasnt even supposed to check it yet. I am buying it at a buyhere/payhere lot in lincolnton, nc and it was as is. The car has drove perfect until now. I have only had it less than 4 weeks and they wont do nothing about it. I need some kind of insight please!
JDL
  • 16,098 POSTS
If you let it run out of oil, you may have ruined the engine. Is the engine froze-up? When you try to crank does the flywheel and pulleys turn? Check cylinder compression.
SEXYLADYKRISTI84
How do you know if the engine is froze-up?
JDL
  • 16,098 POSTS
Does the accessory pulleys, under the hood, turn when you crank it? If they do it isn't frozen.
ERINM1022
  • 2004 MAZDA 6
  • 6 CYL
  • FWD
I own a mazda 6 that was stuck in 3rd gear and the car was puttering and just died when I try to start it everything comes on but the car doesn't start. The guage needles go up and down. Also the battery light flashed on and off 2 weeks ago and again earlier today.
