Emergency shut off switch
LEANNE HALL
  • 2000 JEEP CHEROKEE
  • 6 CYL
  • 129,660 MILES
Jeep will not start after jacking up to change brake pads. Where is the emergency cut off switch?
Saturday, January 22nd, 2011 AT 11:02 PM
WRENCHTECH
  • 20,757 POSTS
It doesn't have one. That is found on Fords only. Read the guides below, they will help you figure out the problem
Monday, December 10th, 2018 AT 6:03 PM
MUSTYMILLER
  • 1993 JEEP CHEROKEE
We have the vehicle listed above (Country) that we have replaced the fuel pump on, but we are still not getting any fuel. Checked all the fuses and relays, and was told it is probably the cut off switch, but we do not know where that is located at. Can you tell us where to find it?
Wednesday, February 3rd, 2021 AT 2:45 PM (Merged)
CARADIODOC
  • 33,743 POSTS
These cars do not have a cutoff switch it is probably the pump itself which is common. Here is a guide to help you see what you are in for when doing the job and diagrams below to help you see what it will be like for your car:
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Disconnect negative battery cable. Release fuel system pressure. See, fuel system pressure release. Raise and support vehicle. Remove fuel tank filler and vent hose at filler tube. Remove rear tow hooks (if equipped). Remove skid plate.
Remove trailer hitch (if equipped). Remove exhaust tailpipe heat shield. Disconnect fuel supply line at filter. Disconnect fuel return and vent lines at tank. Disconnect fuel pump module harness connector. Support fuel tank with transmission jack.
Remove tank strap nuts and move straps away from tank. Lower right side of tank while feeding fuel hoses through access hole in body. Remove filler hoses from tank. Insert siphon hose and drain tank. Lower and remove tank. To install, reverse removal procedure.
Cheers
RICHARD CHAP
Yes, that was it. Took me awhile to drop the tank but the dirt inside was causing the issue. So I flushed it out and got a new pump for $230.00 on Amazon all fixed! Thanks for the guide.
POCKETKNIFE1979
  • 1989 JEEP CHEROKEE
Electrical problem
1989 Jeep Cherokee 4 cyl Four Wheel Drive Automatic
Does it have reset switch? And where is it located?
Don't bother looking it doesn't exist
