One night I slammed on the horn button to avoid an accident, since then the horn will not work.
Tuesday, December 25th, 2012 AT 12:31 AM
MECHANIC
The horn pad may be damaged. It most likely needs to be replaced.
It may be part of the air bag. Call the dealer and ask them if it can be purchased separately
SPONSORED LINKS
Tuesday, December 25th, 2012 AT 12:44 AM
KHLOW2008
MECHANIC
Check the fuse and horn first.
Tuesday, December 25th, 2012 AT 2:08 AM
MICHAELKSMITH1970
MEMBER
2002 NISSAN SENTRA
1.8L
4 CYL
AUTOMATIC
120,000 MILES
Horn does not work. Twelve volt system with good battery. When ignition is on there is only 6.8 volts and one and five on the horn relay. Have no idea why.
Monday, May 11th, 2020 AT 11:47 AM
(Merged)
KEN L
MASTER CERTIFIED MECHANIC
Here is a wiring diagram (below) for the horn and a couple of guides to help you do some testing. Unplug the horns while testing it sounds like it might be shorted out.
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Image (Click to make bigger)
(Merged)
MICHAELKSMITH1970
MEMBER
This doesnt help. I am a mechanic and an electrician so I know how to troubleshoot and have already taken those steps. What I need help understanding is why the relay block is only receiving 6 volts when there is NO short in the system.
SPONSORED LINKS
(Merged)
KEN L
How many volts does the battery have? There is a main feed into the fuse block if you have 12 volts there then the fuse block is bad and needs replacement or repair. I would check the power coming off of the ignition switch and accessory relay as well.
Here are more wiring diagrams (below)
Images (Click to make bigger)
(Merged)
ZELLDOG93
MEMBER
2002 NISSAN SENTRA
4 CYL
FWD
AUTOMATIC
100,600 MILES
Why wont my horn work in my 2002 nissan sentra gxe? I have replaced the relay the horn its self and the fuse that is meant for the horn.
(Merged)
MECHANIC
Sounds like you need to open it up and check the horn button switch
(Merged)
ZELLDOG93
MEMBER
So you mean that I have to take apart my steering wheel? I havent done that yet would you be able to explain how to do it safely? Or send me a link that explains?
(Merged)
NONDRIVER
MEMBER
1 POST
2000 NISSAN SENTRA
Engine light stays on and horn doesn't work. If it is a fuse how do I know which fuse goes to what?
(Merged)
MECHANIC
The owner's manual should show which fuse is for the horn. However, that has nothing to do with the check engine light. You need to have the computer scanned to determine what trouble code/s are stored in the car's computer. Most parts stores will do it for free.
(Merged)
88COOLJ
MEMBER
2000 NISSAN SENTRA
4 CYL
FWD
AUTOMATIC
164,000 MILES
The horn does not work. I have checked all the fuses and all ok. I have check the horn itself it works. Is there any other fuses or relays under the hood that I can check or replace.
SPONSORED LINKS
(Merged)
BLUELIGHTNIN6
MECHANIC
Check horn relay, it is located on the fuse block (behind left side of dash)..
(Merged)
LAB
MEMBER
1 POST
1997 NISSAN SENTRA
6 CYL
FWD
AUTOMATIC
53,000 MILES
Suddently the horn on this car is not working. As you can see with the mileage it has not been driven much because it is owned by a senior citizen who rarely drives.
Can you advise on repair, can we do this ourselves for her? Thanks
(Merged)
ZACKMAN
MECHANIC
B14 Sentra horn has a tendency to just quit working. I advise that you replace it with an aftermarket one from any auto parts store. Should cost around $15.
