Front vents no airflow
MTVUFG8R
  • 2006 HONDA ODYSSEY
Air Conditioning problem 6 cyl Front Wheel Drive Automatic 85000 miles
Rear a/c and heat work fine via front and rear controls. Front has no airflow (cold or hot) from vents. Is there a separate blower for front and rear or is it the same? Is there a fuse for each, etc? What can I look for.
Thanks, Mike
Sunday, November 7th, 2010 AT 12:57 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,110 POSTS
Yes there is a separate blower fan motor for the front the of the car, Here is a guide and some diagrams (below) that will help you get the problem fixed.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Here is a guide to help check the electrical, check the fuse and the relays as well/
and
and
Please run some tests and get back to us we are interested to see what it is.
Cheers, Ken
Wednesday, July 12th, 2017 AT 8:26 PM
KLTFAUGHT
  • 6 CYL
  • 72,000 MILES
My front heater fan stopped working, the rear works fine only the front. Is there a fuse for this fan that would cause this or is it something more serious.
Thanks
KFaught
Tuesday, April 23rd, 2019 AT 6:36 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Check fuses under hood fuse and relay box also check fuses under dash fuse and relay box
