Heater not working!
NATEW51
  • 1999 HONDA ACCORD
  • 6 CYL
  • FWD
  • 137,000 MILES
Hi Everyone, I've got a 99 Honda Accord and I've been fighting heater issues for a 2 years now. There really doesn't seem to be any rhyme or reason as to why it is not working properly and the shops have not been able to really figure it out either. The core is not leaking and the hoses in and out of the heater core are good and hot, so the water is circulating. Last time I had it worked on was exactly 1 yr ago. The flushed the heater core and actually reverse flushed it, but I'm not 100% sold that that is actually the issue, because nothing ever really flushes out. The heater has been working great up until 2 days ago when my alternator went. I've replaced the alternator and now the only time the heater seems to blow warm is when I idle it up to about 3K. As soon as I back off, the heater cools off. Could this be the core is just bad or could it be something with electronic doors not opening and closing properly due to the issue I had w/ the alternator. The car has climate control, and I just hate to pull the heater core unless absolutely necessary because it is such a huge job and will cost lots of $'s. Any help would be very much appreciated. Thanks in advance!
Sunday, January 17th, 2010 AT 12:06 PM
KHLOW2008
  • 41,815 POSTS
Hi natew51,
Try entering the self diagnostic to see if you can come up with anything.
ENTERING SELF-DIAGNOSTICS
1 . Turn ignition on. Turn blower switch OFF. Place recirculation control knob in recirculated air position (indicator light will come on). Press and hold recirculation control switch to fresh air position (indicator light goes off).
2. Continue to hold recirculation control switch until indicator light comes on for 2 seconds. At this point it will blink the Diagnostic Trouble Codes (DTCs) to indicate the faulty component. One blink indicates air mix control motor, 2 blinks indicates mode control motor, and 3 blinks indicates evaporator temperature sensor. If indicator lights come on, test appropriate component.
https://www.2carpros.com/forum/automotive_pictures/192750_HVACDiagnostic99AccordFig06_1.jpg
NOTE:
Fault information is not retained in memory. In case of multiple problems, the light will indicate the DTC with the least number of blinks.
Wednesday, January 20th, 2010 AT 11:40 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,904 POSTS
These cars had a problem with trapping air inside the heater core which it sounds like is your problem. With the car nice and hot with the heater running full blast engine running as well jack the rear of the car up as high as you can, this will release the air pocket and make the heater work again.
Here is a guide that can help as well.
https://www.2carpros.com/articles/car-heater-not-working
Cheers, Ken
Tuesday, January 30th, 2018 AT 12:14 PM
NATEW51
You are a genius Ken that was the problem all along. I will remember this site well, you saved me my sanity!
Tuesday, January 30th, 2018 AT 12:15 PM
CSHOFFEITT
  • 1999 HONDA ACCORD
  • 4 CYL
  • FWD
  • 173,000 MILES
My '99 Honda has good heat as long as the engine is over 2,000 rpms, but is only luke warm when idling. Does this mean I need to replace the heater control valve? (Hoses, coolant and thermostat replaced in November)
Tuesday, December 1st, 2020 AT 11:06 AM (Merged)
This is one of two issues which one is the control cable. I attached the info for an adjustment and a common cause of this issue. Inspect the cable as shown and see if it has slipped off.
If not, you most likely have a restriction in the heater core or an air pocket. We want to check the level of the coolant and top it off if it low. Then you will want to pressure test it. Here is a guide that will help with that.
https://www.2carpros.com/articles/radiator-pressure-test
and
Then I attached the process for the heater core. We want to check the temp on the hoses coming from and going to the heater core. When the engine is hot, and the heater is on full hot, they should be too hot to touch. If they are not then you have an issue with the heater core.
Let us know what questions you have. Thanks
GMAC0603
  • 1999 HONDA ACCORD
Heater problem
1999 Honda Accord 4 cyl Two Wheel Drive Automatic 124KM miles
Hi experts, I'm not getting any heat even though fan works fine, the knob isn't stripped, I can hear a change of wind sound when I go from cold to hot on the dial. Not even warm heat is coming out.
Thanks in advance
F4I_GUY
  • 3,302 POSTS
Your heater core is most likely clogged. Try to flush it out, or replace it.
KEN L
  • 42,904 POSTS
Is sounds like the engine can be low on coolant or you have a temperature blend door actuator that has gone out. Can you check the coolant level and get back to me?
Here is a guide that can help as well:
Please run down this guide and please report back.
Cheers, Ken
ANIRBAN TARAFDER
  • 1999 HONDA ACCORD
  • 4 CYL
  • FWD
  • 96,000 MILES
I have this strange problem. Heater is not working at postion 1. At position 2 it blows hot air only if speed is above 40 mph. When I stall the engine cool/normal air flows. At position 3 and 4 again the temp falls for the hot air.
I got my thremostat changed but still problem persists.
Tuesday, December 1st, 2020 AT 11:07 AM (Merged)
KHLOW2008
  • 41,815 POSTS
Hi Anirban Tarafder,
Seems there is insufficient coolant flow to provide the heat and you need to check,
1. Clogged heater hose.
2. Heater valve not opening sufficiently due to operating cable out of adjustment.
The blower speed resistor is bad so you don't have 1st speed.
MAGNOGREATO
  • 1998 HONDA ACCORD
  • 4 CYL
  • FWD
  • 112,000 MILES
My car is the LX model. It is putting out next to nothing in heat. The temperature gauge is reading upscale, indicating heat, but heat control is all the way up and blows out no 'hot' air which may be the heater/temperature control may be bad(?) How to verify that or where should I look?
Tuesday, December 1st, 2020 AT 11:08 AM (Merged)
CARADIODOC
  • 33,743 POSTS
Feel the two small heater hoses under the hood. They should be too hot to hold onto for very long. If they are cool, suspect a plugged heater core. They can usually be back flushed with a garden hose.
Here is a guide that can help fix the problem:
caradiodoc
Check and test the thermostat, heater core if it is clogged, heater control valve and the air blend door/actuator.
CARADIODOC
  • 33,743 POSTS
Do you have a temperature gauge on the dash? If so, is it reading in the "normal" range. If it is low, suspect the thermostat is stuck open. You are going to have to go out and feel the hoses.
Caradiodoc
MAGNOGREATO
Gauge is normal. Okay I got the point about the hoses. What is an air blend door/actuator and how do I know if I have got one anyway? Are they on a 1998? I can back wash the heater but if it is the front panel control how do I access it without messing up the dash?
CARADIODOC
  • 33,743 POSTS
The blend door selects between heated and non-heated air for the desired temperature of the incoming air. The actuator depends on the type of control system you have. If you have the common sense manual levers, knobs, and switches, there will be cables that could become disconnected or out of adjustment. If you have computer controls, the actuators are usually electric motors with position sensors. Either system could use vacuum motors to move the various doors around, but those are typically used for things that are turned either fully on or fully off. A door to the defroster would be fully open to defrost the windshield, or be fully off when you want toasty feet. Blend doors are not usually set for full hot or full cold all of the time so vacuum motors do not work well for that function.
If you have a manual slide lever for temperature, you might be able to hear the blend door hitting its stops when you move it back and forth. Some cables, such as on Dodge Caravans, are self-adjusting by means of the cable sliding through fingers of a clip on the actuator lever. If the door becomes rusted tight in the cold position during the summer, it will not move in the winter, but the cable will slide giving the impression the door is working. When that happens, you will not hear the door move when you slide the lever back and forth.
If you have vacuum controls, you should be able to hear some of the doors moving when you switch to different functions, and you will often hear something moving around when you stop the engine and vacuum goes away. The systems are spring-loaded to go to the defrost position when there is no vacuum to insure the windshield can be cleared. When none of these controls work, a leak in the vacuum hose can be suspected, or the hose could be disconnected.
Computer controls often have self test/calibration procedures that can get pretty complicated. Problems with these controllers often leads to flashing display lights or the system has gone out and has no lights turned on. It's common for them to be intermittent too. If you get hot air sometimes and not others, suspect the computer. Otherwise they typically do not go out of calibration unless the battery was disconnected or run dead.
The two most important clues are whether the two heater hoses are hot and if you can hear something moving when you adjust the temperature control. Beyond that, it becomes a process of eliminating all other possible causes before condemning the computer. Most manual controls can be accessed under the dash or often by removing the glove box liner, radio, or heater controls. Computer controlled actuators typically require removing the steering column and dash assembly to remove the heater box. That gets real involved and is definitely not a do-it-yourselfer project. Experienced mechanics know how to diagnose the most likely cause of the problem before removing anything, and they know what to look for when they get the heater box on the workbench.
Caradiodoc
JAMES GREENE
  • 7 POSTS
  • 1999 HONDA ACCORD
  • 4 CYL
  • MANUAL
  • 191,000 MILES
I press the air button on dash no air no light
I press the heater button ---no heat no light
I was told --a rister proble? If it is that then why no heat or air even though the blower blows?
Any suggestions? Second submission
2CARPRO JACK
  • 11,533 POSTS
So basically nothing on the climate controller works except the blower control? Have you checked all fuses with a test light? Did this happen all of the sudden or has it been intermittent until now?
JAMES GREENE
  • 7 POSTS
It is my sons car, he said the air heat sometimes did not work but now it happened all of a sudden.
What location should I check the fuses?
Under the hood? The drivers side of the dash or the passenger side of the dash?
Thanks for replying.
2CARPRO JACK
  • 11,533 POSTS
So it has been going away, and has now quit. I would check every fuse with a test light. Sometimes part of the HVAC system will be fused under the hood as well as in the interior. It sounds like it may have an issue with the blend door, if it is not doing what you request temperature wise.
