Ignition cylinder firing order
DAN D DIVER
  • 1999 HONDA ACCORD
Can I get the engine firing order please?
Do you
have the same problem?
Friday, November 14th, 2008 AT 6:16 PM
ZACKMAN
http://www.2carpros.com/forum/automotive_pictures/55316_Accord_Firing_Order_1.jpg
Will this work?
Saturday, November 15th, 2008 AT 12:13 AM
PELLETIERS R US
  • 1996 HONDA ACCORD
Four cylinder front wheel drive automatic 17,600 miles. Would you please send me a diagram of the firing order from the distributor to the engine? I got mad at my husband and took the wires out and now it is not running properly. So to redeem myself he said I have to find out the firing order.
Thank you, Kim P.
Sunday, January 5th, 2020 AT 8:04 PM (Merged)
Here is the firing order for you engine (below):
http://www.2carpros.com/forum/automotive_pictures/12900_fo_86.jpg
JCARGIN
  • 1996 HONDA ACCORD
  • 2.1L
  • 4 CYL
  • FWD
  • 187,000 MILES
I replaced the distributor and it will not start.
HEYMAN1104
  • EXPERT
A couple of questions. 1) Did you replace the whole distributor? Or just the cap and rotor? 2) If you replaced the whole distributor, did you get cylinder one's piston at top dead center before removing the old distributor?
Let us know.
JCARGIN
No I did not. I have no idea how to do that.
HEYMAN1104
  • EXPERT
Okay I will assume that means that you pulled the whole distributor (shaft and all). When you remove a distributor, you are supposed to get cylinder one's piston at top dead center first so that the timing chain/belt stays on and everything stays in the right place. You get cylinder one at TDC by pulling the spark plug, disconnecting the coil wire, and simply putting a ram rod down into the cylinder to check the position of the piston. Then you take the ram rod out, give the key a quick turn (just to turn the engine a bit) and measure again. Do this several times until you are confident that the piston is as high up as it gets.
Since the timing belt is now off and the top and bottom half of the engine are out of time with each other, you will need to have the timing belt replaced and the engine put back into time. Hopefully none of the valves are bent. I would highly suggest getting a professional to take it from here.
BLACK932
  • 1995 HONDA ACCORD
  • 4 CYL
  • 150 MILES
Spark plug cross up and getting no fire
http://www.2carpros.com/forum/automotive_pictures/12900_foh_1.jpg
DESTILLO
  • 1995 HONDA ACCORD
Engine Mechanical problem
1995 Honda Accord 4 cyl Automatic 146679 miles
What is the Firing Order
RACEFAN966
  • EXPERT
It is 1,3,4,2. Here is a picture so you can see the distributor and its rotation as well as the firing order. Let me know if you need any thing else.
http://www.2carpros.com/forum/automotive_pictures/249564_Graphic_129.jpg
BILLYHIBBS64
  • 1993 HONDA ACCORD
  • 4 CYL
  • FWD
  • 210,317 MILES
What is the cylinder order for the motor and the distributer firing order for thne spark plug wires
KHLOW2008
  • EXPERT
Hi billyhibbs64,
Firing order is 1 - 3 - 4 - 2, from driver side.
JEANNIE1963
  • 1992 HONDA ACCORD
Engine Performance problem
1992 Honda Accord Automatic
Could you please tell me the firing order of an Accord LX, and also, when it idles it seems to speed up and then slow down.
Test your electric air control valve and also see below for the firing order.
http://www.2carpros.com/forum/automotive_pictures/12900_honda_firing_order_1.jpg
LADYTRUCKER033
  • 1991 HONDA ACCORD
  • 156,999 MILES
My 1991 honda accord stalled out, got it going again. It stalled again and now it turns over but wont start!Acts like theres no fire or no fuel!
JDL
  • EXPERT
Have a helper crank it while you check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. Any applicable trouble codes? How long since a tune-up?
JDL
  • EXPERT
My info shows this for the location of fuel filter. Below.
Relieve fuel pressure first.
JDL
  • EXPERT
Sorry, you asked for relay and I gave you fuel filter.
JDL
  • EXPERT
The main relay is under driver-side of dash, top relay in picture.
