Firing order needed
ALEX GATLIN
  • 2001 HONDA ACCORD
  • 2.5L
  • 4 CYL
  • 150,000 MILES
Can I get the firing order [1-3-4-2) with the engine rotation along with a diagram of the spark plug wires on the distributor cap please?
Thanks,
Alex
Thursday, April 23rd, 2020 AT 11:03 AM
I attached the info you requested. Your cap should marked for number 1 and then the others are counterclockwise around the cap.
Take a look at the documents and let me know if you have questions. Thanks
Thursday, April 23rd, 2020 AT 11:54 AM
PHILIPN
  • 2001 HONDA ACCORD
  • 4 CYL
  • 4WD
  • 150,000 MILES
I was doing a tune up on my Accord and I think I must have the wiring wrong or I hit the timing, so I need to know what the wiring and timing is for my accord. It will not start. Can you help?
Thursday, December 17th, 2020 AT 8:16 AM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi philipn,
https://www.2carpros.com/forum/automotive_pictures/192750_Distributor01Accord_1.jpg
Firing order is 1 - 3 - 4 - 2.
DAN D DIVER
  • 1999 HONDA ACCORD
Can I get the engine firing order please?
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_Accord_Firing_Order_1.jpg
Will this work?
BLONGVUE
  • 1998 HONDA ACCORD
  • 4 CYL
  • FWD
  • 180 MILES
I took off the spark plug wires and forgot which one goes where. Can you please help me out. It's on a 98 Accord 4cyclinder, 2.3 liter with v-tech. Thanks for your help.
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_honda_accord_1.jpg
Hello, my info showed this.
JA_PONTIGO
  • 1997 HONDA ACCORD
Engine Performance problem
1997 Honda Accord 4 cyl Front Wheel Drive 140000 miles
I drove the car from FL to VA, when we arrived in VA it was snowing and the next day the car would not start. After a couple of days when the weather got warmer the car turned on. In summer time when it rains it doesn't turn on either until the weather gets dry and the sun comes out. I have changed: Spark plugs, spark plugs wires, distributor, checked if gas was coming in engine and it is, charged battery at advance auto part and battery is fine, changed starter not to long ago but the problem persist. I would like to know what else do you advise me to check because I runned out of ideas of what is wrong with my car.
I also took out the spark plugs cables and did not pay attention of the position of the cables in the distributor cap. Could you tell me how to put them back where they belong.
KHLOW2008
  • 41,814 POSTS
Hi ja_pontigo,
Here are the diagrams for the firing order.
https://www.2carpros.com/forum/automotive_pictures/192750_FiringOrder97Accord4cylFig01_1.jpg
Check the PGM-FI main relay for the difficult starting.
PELLETIERS R US
  • 1996 HONDA ACCORD
Four cylinder front wheel drive automatic 17,600 miles. Would you please send me a diagram of the firing order from the distributor to the engine? I got mad at my husband and took the wires out and now it is not running properly. So to redeem myself he said I have to find out the firing order.
Thank you, Kim P.
Thursday, December 17th, 2020 AT 8:17 AM (Merged)
Here is the firing order for you engine (below):
https://www.2carpros.com/forum/automotive_pictures/12900_fo_86.jpg
BLACK932
  • 1995 HONDA ACCORD
  • 4 CYL
  • 150 MILES
Spark plug cross up and getting no fire
https://www.2carpros.com/forum/automotive_pictures/12900_foh_1.jpg
DESTILLO
  • 1995 HONDA ACCORD
Engine Mechanical problem
1995 Honda Accord 4 cyl Automatic 146679 miles
What is the Firing Order
RACEFAN966
  • 5,029 POSTS
It is 1,3,4,2. Here is a picture so you can see the distributor and its rotation as well as the firing order. Let me know if you need any thing else.
https://www.2carpros.com/forum/automotive_pictures/249564_Graphic_129.jpg
JJONES21
  • 1994 HONDA ACCORD
  • 2.2L
  • 4 CYL
  • MANUAL
  • 119,242 MILES
I replaced my distributor and I forgot to diagram the firing order. Is there a diagram of the firing order?
HARRY P
  • 2,292 POSTS
Hello and thanks for using 2CarPros. The are two different 2.2L four cylinder engines. VTEC and non-VTECH. I'm attaching the images for both. Check your vehicle emissions label to know which diagram to go by. It should be under the hood somewhere. If not, post the VIN number in this thread and I should be able to look it up for you.
Thanks again for using 2CarPros. Good luck!
JJONES21
Vin#1HGCD553XRA128479
And do you have the diagram for the distributor?
HARRY P
  • 2,292 POSTS
Here you go. This applies to both the regular 2.2 engine and the VTEC engine. Honda is less than forthcoming about telling me which engine your car has. Anyways, let me know if there's anything else that I can do.
JESSE OWENS
  • 1994 HONDA ACCORD
  • 2.2L
  • 4 CYL
  • 4WD
  • 146,000 MILES
I forgot the firing order for my car it is the LX model and now I hear a misfire. The reason why is due to me replacing my distributor I had carelessly unhooked the ignition wires. Now I go on the web and I cannot even find it.
Thursday, December 17th, 2020 AT 8:18 AM (Merged)
