1996 Honda Accord
WILLYQ
  • 1996 HONDA ACCORD
1996 Honda Accord 4 cyl
I have a 96 honda accord lx that has no spark and no signal or codes enter the auto scanner. We have changed everything (distributer, map, coil, spark plugs, etc.) And the panel was also checked and it seems to be working. The car cranks, but does not start. Thanks
Do you
have the same problem?
Tuesday, February 3rd, 2009 AT 8:21 AM
KHLOW2008
  • EXPERT
Hi willyq,
If any repair was carried out on the engine, then you need to check the ECM grounds at the thermostat housing.
Does the Check Engine Lamp shows for 2 seconds and goes of at initial ignition switch ON?
Is there battery voltage at the Black/Yellow wire of distributor with ignition switch ON and while cranking?
Are the dash lights showing while cranking?
Friday, February 13th, 2009 AT 11:22 AM
