HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
GMC
Sierra
Climate Control
Heater
1997 GMC Sierra heater
BREEZEJAMES
MEMBER
1997 GMC SIERRA
V8
4WD
AUTOMATIC
3,000 MILES
My heater works but it dosent blow any heat out on any setting or speed
Sunday, February 10th, 2008 AT 5:02 PM
MASTERTECHTIM
MECHANIC
Double check your coolant level in the radiator, if ok I would install new thermostat and blow out the heater core. This should take care of it.
Sunday, February 10th, 2008 AT 5:51 PM
Please
login
or
register
to post a reply.
Related Heater Content
Heater Will Not Turn Off
Heater Does Not Turn Off.
Asked by
memike55
1 ANSWER
1 IMAGE
1999
GMC SIERRA
GUIDE
Heater
Once the engine has been started and has run long enough to warm up the hot coolant is transferred into the heater core which is located inside the passenger compartment via...
Heater Will Only Work When Start With Command Start
I Can Have Heat If I Start Truck With Remote In Neutral And Don't Use Brakes?
Asked by
sue Familton
1995
GMC SIERRA
2001 Gmc Sierra Heater Will Not Turn Off
I Have A 5.3 Liter Engine On A 2001 Sierra 4wd. If I Run The Heater At High For More Than A Minute, It Will Not Turn Off. I Am Able To...
Asked by
BigBen76
1 ANSWER
2001
GMC SIERRA
Cabin Air Filter
This Is And Slt Version. Does It Have A Cabin Air Filter And If So How Do I Change The Cabin Air Filter?
Asked by
ST3
3 IMAGES
2013
GMC SIERRA
1999 Gmc Sierra Heater Fan & 4 Wheel High/low...
The Heater Defrost Fan Motor Works Intermitiately. Also It Appears To Quite Functioning When The Transmission Refuses To Shift Into 4 Wheel...
Asked by
Rob Plance
1 ANSWER
1999
GMC SIERRA
VIEW MORE
Heater Not Working
Heater Not Working
Blend Door Actuator Replacement
