Fuel pressure regulator
HOOK1
  • GMC C1500
I have a '97 GMC 1500 2wd 5.0 ltr. Auto.
Installed a new fuel pump last week. Engine died today under normal running conditions. Fuel pump is operating. Engine won't start unless gas is added manually.
I suspect the culprit is the fuel pressure regulator, but would like confirmation.
Thanks in advance,
Hook1
Monday, August 27th, 2007 AT 4:32 PM
HOOK1
  • 6 POSTS
I forgot to mention the above truck has 155,000 miles.
Thanks,
Hook1
Monday, August 27th, 2007 AT 4:34 PM
When you turn key On-do you hear the fuel pump come On for a few secs?
Monday, August 27th, 2007 AT 4:35 PM
HOOK1
  • 6 POSTS
Yes, The fuel pump does run, I can hear it running.
Thanks,
Hook1
Monday, August 27th, 2007 AT 4:41 PM
Don't feed it-crank engine over is the injector/s clicking listen to it real close.
If you can hear it clicking-check the actual fuel pressure with a gauge.
Monday, August 27th, 2007 AT 5:33 PM
HOOK1
  • 6 POSTS
I replaced the fuel filter today, and I have a new regulator.
I do hear the injectors clicking.
I don't have a fuel pressure gauge.
I'd like to make sure the signals are being delivered to the injectors. Would they be clicking if there wasn't a signal being sent?
Hook1
Tuesday, August 28th, 2007 AT 4:38 PM
If you can hear it clicking it means its pulsing-could be the injector/s is clogged up or no fuel pressure even if you hear the pump. Could be your oil pressure sending unit this the one that powers it after the fuel pump relay does its thing.
Tuesday, August 28th, 2007 AT 5:25 PM
HOOK1
  • 6 POSTS
I'm not sure I understand how the oil pressure sending unit affects the fuel flow situation. Can you provide more information.
Thanks for all the help,
Hook1
Tuesday, August 28th, 2007 AT 7:26 PM
RMCHAMBERS
The PCM monitors oil pressure, if the computer senses no oil pressure it cuts off the injectors (to save the engine from a siezure). This can stall an engine at low idle, normally at higher RPM's the oil pressure is high enough to keep the computer happy.
I used an old guage off a tire foot-pump. Hooked it to some fuel line, then attached that to the engine side of the fuel filter and turned the key to ON (but not start) and see what pressure shows. You need to put circular clamps on each end of the hose as the pressure can get right up there and you don't want gas spraying all over.
Tuesday, August 28th, 2007 AT 8:23 PM
Mr Hook1 this is how it goes
Oil sending unit /Fuel pump circuitry:
https://www.2carpros.com/forum/automotive_pictures/12900_oil_sending_unit_and_fuel_pump_circuit_4.gif
Wednesday, August 29th, 2007 AT 12:05 AM
HOOK1
  • 6 POSTS
First of all, thanks for all the help!
Checked the fuel preesure and found that it went to 35 lbs. When I turned the key to the on position, but immediately dropped to zero. Decided it might have had a faulty check valve. Replaced the fuel pump and the engine starts now.
I replaced the FPR and the Oil pressure sending unit, to no avail.
My question is this:
Could a faulty fuel pressure regulator cause a new fuel pump to go bad, or burn out?
Hook1
Friday, September 28th, 2007 AT 7:17 PM
You have a fuel pressure leakdown could be one or more leaky injector/s- Get it to start pull the vacuum hose at the regulator the pressure should increase between 8-10lbs without the vacuum-and should drop down to normal range when vacuum is reapplied to it-don't do this the regulator is bad.
Friday, September 28th, 2007 AT 9:54 PM
