Easy way to change fuel pump filter
FIRERATT68
  • 2002 DODGE DURANGO
Is there a trap door in the back to get to the fuel pump without taking the tank off?
Wednesday, January 13th, 2010 AT 3:50 PM
BLUELIGHTNIN6
  • 16,542 POSTS
For fuel pump and/or filter removal, you will have to remove the fuel tank. Here are two guides to help you step by step.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
and
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Wednesday, January 13th, 2010 AT 3:55 PM
RICH800
  • 2000 DODGE DURANGO
  • V8
  • 61,000 MILES
Instead of pulling the fuel pump out of the tank when bad can I install a in line electric fuel pump
Saturday, March 30th, 2019 AT 1:05 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
You could but it's more trouble in the end, probably take longer to do this than replace the stock fuel pump. Would have to find a fuel pump that not only pushes but also pulls, since it would have to pull fuel from the tank into the pump and then push it onward, all of this having to be done at a specific fuel pressure also. You would also have to relocate all of the fuel pump wiring.
VIPERCALBO
  • 1999 DODGE DURANGO
  • 5.9L
  • V8
  • 4WD
  • 156,000 MILES
I Just replaced my fuel pump and now it cranks but after running for 20 mins or more. When I turn my durango off it just turns over but doesn't crank. Go back next morning my durango cranks again. Then after 20mins or more of running my Durango will not crank?
HMAC300
  • 48,601 POSTS
Try resetting security system may have engaged partially then get it scanned for codes by a mechanic
VIPERCALBO
Thank You I will give your advice a try
RENEE L
  • ADMIN
  • 1,257 POSTS
It sounds like the battery cables are dirty. here is an article that will help you:
Please let us know what you find so it will help others.
ROBBYSMOM1
  • V8
  • 15,000 MILES
Car will periodically not start but is not a starter issue, that has been replaced recently - we don't think it is bad gas but for the past 4 days, the car would not start and then this morning, it started immediately and ran fine. This same thing happened 2 weeks ago, one minute it was running fine - then turned it off and when attempted to start again, it wouldn't and then a couple of days later - it was fine. Does that sound like fuel pump? Car also has new battery.
BLUELIGHTNIN6
  • 16,542 POSTS
Could be. Next time won't start try knocking on the fuel tank. This will jar the fuel pump and if pump is faulty, this will almost always cause the pump to start again.
Next time it happens-don't wait for nothing-do below to determine if its fuel or spark issue.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
RANDY3357
  • 1998 DODGE DURANGO
  • V8
  • 4WD
  • 170,000 MILES
Have a 1998 dodge durango, keep stalling out, it is worse when it is cold after warms up, its better. Have replaced the fuel pump. Could it be a vauum from a gasket?
WRENCHTECH
  • 20,758 POSTS
You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
CHRISREAVES
It needs a fuel pump but ended up going out to get a new pump with the gas tank too. So now I took the straps off to loosen the tank. How do I get to the hoses thats connected to the tank and if its hard to do how do I remove the fuel pump without the hassle of the gas tank
Wednesday, December 18th, 2019 AT 10:24 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Support tank and drop down to gain access to top hoses and line to disconnect
doing tank or pump, tank must come down
good luck
LISA PAGEL
  • V8
  • 4WD
  • 199,000 MILES
How difficult is it to replace a fuel pump? Where is it located? Estimated costs at an independent repair shop?
Wednesday, December 18th, 2019 AT 10:25 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Its in the fuel tank
not an easy think to do
over $500
SERVICE WRITER
  • 9,123 POSTS
Yeah they are pricy.I prefer to use the oem brand on them. They have the regualtor, pump and sending unit all rolled into one.
Unknown factors will be the strap and line issues.
Independents use differnent pricing matrixs, talk to them about the cost first.
2CP-ARCHIVES
  • 4,540 POSTS
  • 83,000 MILES
Hi guys,
How do you know for sure if you need a fuel pump? Do you know a fair price for the cost?
SATURNTECH9
  • 30,869 POSTS
Which engine do you have?Also what are the symptoms?Any codes in the computer?Have you checked the actual fuel pressure?
TRISH D
  • 5 POSTS
Thank you for your quick response. It cranks about 4-5 times in the morning. It is at the dealer and they are thinking the fuel pump. I have the small V-8 - 5.9. 2WD. They are suppose to do a diagnostic test, but can't find the problem yet.
