HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Taurus
Engine
1996 Ford Taurus replacing pvc vale
KEITH1
MEMBER
1996 FORD TAURUS
6 CYL
2WD
AUTOMATIC
146,000 MILES
Were is it located on the engine
Saturday, January 5th, 2008 AT 10:44 AM
ZUE
MEMBER
Where is WHAT located? Provide more details.
Saturday, January 5th, 2008 AT 11:01 AM
FLEXY5
MECHANIC
The PCV valve is located on the back side of the engine under the intake. It can be replaced without removing the intake.
Saturday, January 5th, 2008 AT 9:04 PM
Please
login
or
register
to post a reply.
Related Engine Content
The Engine Was Not Heating Properly
I Have Replaced The Thermostat And Antifreeze/coolant What Else Could It Be? I Have Also By Recommendation Of A Friend Unhooked Both Cooling...
Asked by
Daemien
1 IMAGE
1996
FORD TAURUS
VIDEO
Turn Over an Engine by Hand | Bar Over
Instructional repair video
GUIDE
Code Reading
A check engine light, also known as a service engine light, or a MIL (malfunction indicator light) is designed to let you know there is a problem with one of your car's...
1996 Ford Taurus Electric Fans
The Fans Continue To Run After The Car Is Turned Off. The Fans Continue To Run When The Battery Is Disconnected I Have To Disconnect The...
Asked by
dhabbott41
1996
FORD TAURUS
1996 Ford Taurus Temperature Indicator
The Engine Temp Indicator Varies Up And Down Especially When Idling. At Speed It Still Varies But At A Lower Range. I Had A 92 Taurus That...
Asked by
Cherad
1 ANSWER
1996
FORD TAURUS
1996 Ford Taurus Runner Stuck
Engine Mechanical Problem 1996 Ford Taurus V8 Front Wheel Drive Automatic Where Is The Runner And How Hard Is It For A Diy To Repair?
Asked by
TBDavis3
1996
FORD TAURUS
99 Taurus Engine Into A '98 Taurus
Hi I Have A Wrecked '99 Taurus (engine Area Unaffected) And A '98 Taurus With A Thrown Rod. My Question Is: Is It Possible And Advisable...
Asked by
ragnarok628
1999
FORD TAURUS
VIEW MORE
Hybrid Engine
Chevrolet Small Block V8 350 5.7L 390HP
Hybrid Car
