1995 Ford Taurus Problem starting at certain temperatures
ED ADOLPH
  • 1995 FORD TAURUS
Engine Mechanical problem
1995 Ford Taurus 6 cyl Front Wheel Drive Automatic 250 km miles
I just purchased a 95 Taurus. The car starts fine in very cold temperatures (-20 Degrees Celsius and colder) Between -15 and 0 degrees it seems to flood. It turns over fine, but will not start. After plugging the car in for a few hours, (the block heater), it will start. I figure it is a sensor but which one? Any suggestions are appreciated.
Saturday, January 31st, 2009 AT 6:22 PM
  • 110,192 POSTS
Hi:
To identify a sensor problem, take it to a nationally recognized parts store and have them scan the computer for codes. If there is a bad sensor, it should show up. Also, make sure the ground wire on the engine block is clean and tight.
Let me know what you find.
Sunday, February 1st, 2009 AT 8:56 PM
