1990 Ford Taurus water pump replacement
MIKE MONTGOMERY
  • 1990 FORD TAURUS
Engine Cooling problem
1990 Ford Taurus 6 cyl Front Wheel Drive Automatic
Need procedure and tips to remove and replace the water pump
Do you
have the same problem?
Friday, October 15th, 2010 AT 9:34 AM
REMOVAL
Drain the engine coolant and disconnect the battery ground cable.
http://www.2carpros.com/forum/automotive_pictures/12900_w1_6.gif
Water Pump Pulley Replacement
Loosen the four water pump pulley retaining bolts, using the accessory belt tension to keep the pulley from turning.
Loosen the alternator belt adjuster jack screw and remove the alternator belt.
Using a 1/2" breaker bar rotate the automatic tensioner down and to the left. Remove the accessory drive belt.
Remove the two nuts and single bolt retaining the automatic belt tensioner to the engine and remove the assembly.
Remove the four water pump pulley bolts and remove the pulley from the vehicle. NOTE: On some vehicles the pulley will not have enough clearance to facilitate removal from the vehicle. In this case, allow the pulley to remain on the hub after the bolts have been removed.
Remove the heater hose from the water pump.
Water Pump Replacement
http://www.2carpros.com/forum/automotive_pictures/12900_w2_12.jpg
Remove the 11 water pump to engine retaining bolts and remove the water pump from the vehicle.
Friday, October 15th, 2010 AT 9:44 AM
Recommended Guides
