Timing marks on the crankshaft for a 2.3L?
JOHN SLONES
  • 1995 FORD RANGER
  • 170 MILES
I recently had to change the timing belt on my truck because it had slipped. I found the markings on the others, but I am unsure of where the marks are for the crank.
Tuesday, September 6th, 2011 AT 1:23 PM
WRENCHTECH
  • 20,757 POSTS
The keyway has to go straight up here is a guide to help you see where the marks are.
https://www.2carpros.com/diagrams/ford/ranger/1995
Saturday, October 27th, 2018 AT 4:29 PM
FROG20015
  • 1995 FORD RANGER
  • 2.3L
  • 4 CYL
  • MANUAL
  • 170,000 MILES
I cannot get it to stay timed.
Wednesday, November 11th, 2020 AT 6:26 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,959 POSTS
Here is a diagram to help, check the tension of the belt also check the bottom drive gear it could be moving around on the key way I have seen this before
Let me know what you find
2CP-ARCHIVES
  • 4,542 POSTS
  • 1995 FORD RANGER
  • 6 CYL
  • 140,000 MILES
1995 Ford Ranger mileage: 140,000. What would cause timing belt to jump a notch?
2CP-ARCHIVES
  • 4,542 POSTS
As the timing belt wears it becomes stretched out and that can cause it to jump.
CJ MEDEVAC
  • 11,004 POSTS
Thats why they really recommend that they be changed at a SCHEDULED INTERVAL, I've mostly seen 60,000 miles being that interval, usually outlined in your owners manual or in the "Scheduled Maintenance" section of a Repair Manual.
Much grief could be avoided, if people would just do this maintenance, instead of waiting till it's too late.
The Medic
DONALDLEDFORD
  • 1994 FORD RANGER
Engine Mechanical problem
1994 Ford Ranger 4 cyl Two Wheel Drive Manual
what are the timing marks and where are they suppose to be
Wednesday, November 11th, 2020 AT 6:27 PM (Merged)
BLACKOP555
  • 10,371 POSTS
Timing marks are used to align the valve timing for the camshaft and crankshaft. they are usually indentations/markings on camshaft and crankshaft pulleys.
https://www.2carpros.com/diagrams/ford/ranger/1994
usually right above the keyway.
XTRAVAGANT1
  • 5 POSTS
  • 1994 FORD RANGER
  • 4 CYL
  • 105,000 MILES
Hello! I was wondering if the engine timing was off, will the ignition coils have spark?
BMRFIXIT
  • 19,053 POSTS
When you say off do you mean off timing or off broken off you should check if the cam turning, and if so check the crank sensor, fuses and relays
