NOTE: 2.0L engine shown, 2.3L engine similar.
With the vehicle in NEUTRAL, position it on a hoist.
Release the fuel system pressure.
Press the quick connect fitting tabs and remove the fuel filter inlet and outlet tubes.
NOTE: Observe the direction of the flow arrow.
Loosen the bracket retaining bolt and remove the fuel filter and bracket assembly.
To install, tighten to 11 Nm (8 lb-ft) .
To install, reverse the removal procedure.
Friday, March 1st, 2019 AT 7:40 PM
(Merged)
