Replacing serpentine belt
WANDRNSTAR
  • 2004 FORD F-250
  • V8
  • 4WD
  • 61,890 MILES
I have to replace the altenator. Taking it off was easy. Now I am trying to get the new one on and put the serpentine belt back on. The engine is so crowded I cannot find the tensioner. Where is it on this engine? 6.0L Turbo deisel.
Thanks,
Vin
Tuesday, December 18th, 2007 AT 5:38 PM
BLACKOP555
  • 10,371 POSTS
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/replace-serpentine-belt
and
https://www.2carpros.com/diagrams/ford/pickup/2004
Tuesday, December 18th, 2007 AT 7:25 PM
FLEXY5
  • 512 POSTS
"By the book" you are suppose to remove the upper fan shroud. On the older 6.0 you had to cut it at a certain groove on either side of the shroud (BRILLIANT!). However, at the dealership, we implemented a shortcut. It's not the greatest way to do it, but it saves 2 hours of time. The belt tensioner is on the passenger side, towards the bottom/middle of the engine cover. If you slide a prybar down, you can push down on the tensioner. DO NOT PRY AGAINST OTHER THINGS! It may take two people to get the job done, but we were able to change a belt on a 6.0 in about 6 minutes flat. Let me know if you have any questions.
Tuesday, December 18th, 2007 AT 9:18 PM
PGANGI
  • 2003 FORD F-250
  • V8
  • 4WD
  • 160,000 MILES
How to remove drive belt. I cannont get room to put tool on tensioner. The clip lock on the tensioner is not working
Monday, January 25th, 2021 AT 7:38 PM (Merged)
MERLIN2021
  • 17,250 POSTS
I use two combination wrenches hooked together to get enough leverage to hold the tensioner while I slip the belt off, and back on.
https://www.2carpros.com/forum/automotive_pictures/62217_wrenches_12.jpg
PGANGI
Thank you for the info. Could you please answer the question?I already know the answer, another site was able to help me. I just want to get my moneys worth.
MERLIN2021
  • 17,250 POSTS
Tis is how I do it if the room is tight, on a rear drive like yours, it's fairly simple. I thought I did answer your question, so I don';t understand the "getting your money's worth" Statement. Serp belt and tensioner is basic stuff, so what is the problem getting the belt off? No leverage? Not accessible? All you do is turn the bolt on the tensioner with some force, this will unwind the tension and allow the removal of the belt. To install it, there is a tool available to put the belt on the lower pulleys if you cant reach them, it's a thin bar with a hook on it.
PGANGI
Never mind. The special tool will not work since the 1/2 drive slot is recessed. So you have to use a 3/8 to 1/2 adapter with a ratchet and a piece of pipe on the ratchet for leverage and it fits in the tight spot on the vehicle I described. This was the answer to the question not here is a picture of how to put 2 wrenches together to gain more leverage. On top of that you never addressed the clip on the tensioner on this vehicle, which by the way is a short cut, if it works, so that yo do not have to uses any wrencehses at all. Now you can answer the next guy's question that is the same as mine with a bit more intelligence.
Later
MERLIN2021
  • 17,250 POSTS
I have never had to use pipe to change a belt. And you can put a wrench on the bolt on the tensioner pulley. Good luck with your intelligent answer.
2CP-ARCHIVES
  • 4,540 POSTS
  • 2003 FORD F-250
  • 60,000 MILES
How do I replace a serpentine belt on a F250 6.0L Diesel truck?
JDL
  • 16,098 POSTS
Note the diagram for single alternator serpentine belt. See #8 that is the tensioner, looks like a drive cavity, don't know the size, 3/8/or a 1/2. Use a long handle rachet or breaker-over, whatever is easier, push to release tension.
WAYNE H
  • 2001 FORD F-250
  • V10
  • 79,000 MILES
How do I change my serpentine belt for my "2001" Ford F250
  • 108,355 POSTS
There is an automatic tensionier that needs released. Once you turn it, the belt will come off. Go to our homepage under the DIY section. Go to belts and it will provide the belt diagram you need for your vehicle.
JACK FRY
  • 1996 FORD F-250
  • 7.3L
  • 4WD
  • 111,000 MILES
What size socket goes on the tensioner pulley to use the belt removal tool?
CARADIODOC
  • 33,760 POSTS
It should be a 15mm. But we just look at what type of tool is needed, and if it's an open-end wrench or socket, we try a few to find the right one. Some replacements use a square drive, usually 1/2", as found on the end of a ratchet or breaker bar.
Here is a guide to help you see what you are in for when doing the job.
and
https://www.2carpros.com/diagrams/ford/pickup/1996
Cheers
JACK FRY
Thank you I got the job done the links really helped!
CARADIODOC
  • 33,760 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers
