HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Engine
1999 Ford F-150 engine went out
NOELSNTN
MEMBER
1999 FORD F-150
Engine Mechanical problem
1999 Ford F150 V8 Four Wheel Drive Automatic
hi my engine went out and I was wondering around how much it would cost to bore it out.
Tuesday, March 24th, 2009 AT 4:25 PM
BLACKOP555
MECHANIC
That is a very variable price. Depends on what the machine shops near you want to charge!
Boring it out, yhoull need new pistons, new piston rings also. You cant just over bore it and expect to use teh same hardware!
Tuesday, March 24th, 2009 AT 9:32 PM
Please
login
or
register
to post a reply.
Related Engine Content
1999 Ford F150 Engine Performace
Eng Stsrts And Runs, Ong Sens New New Egr New Cat Conv. All Codes Clear. After A Short Very Short Time The Exh Man Turn Bright Red, Truck...
Asked by
darrell alford
1 ANSWER
1999
FORD F-150
VIDEO
Turn Over an Engine by Hand | Bar Over
Instructional repair video
GUIDE
Code Reading
A check engine light, also known as a service engine light, or a MIL (malfunction indicator light) is designed to let you know there is a problem with one of your car's...
Where To Attach Engine Hoist
Everything Is Unattached, I Just Can't Figure Out Where Exactly To Attach The Engine Hoist
Asked by
Jennifer100
1 ANSWER
2 IMAGES
2006
FORD F-150
1986 Ford F150 Engine Flutters
Engine Performance Problem 1986 Ford F150 6 Cyl Two Wheel Drive 117000 Miles Truck Runs And Shifts Great But When You Reach 55 Mph It...
Asked by
gbamarex22
1986
FORD F-150
2002 Ford F150 Engine Up Grade
I Have A 2002 F150 6 Cyl With Manual Transmission. I Need More Power. Is It Possible To Install A 4.6l V8 In This Truck That Ford Makes?...
Asked by
cdmastros
2002
FORD F-150
2008 Ford F-150 Engine Coolant
My Engine Coolant Is Low And I Need To Know What Type Of Coolant To Get. Also Can I Just Top Off The Reservoir Or Should I Flush The System...
Asked by
kevinc428
2008
FORD F-150
VIEW MORE
P1000 Trouble
Hybrid Car
