Where is the cabin air filter, and how do I change it?
Tuesday, April 28th, 2009 AT 7:46 PM
KEN L
MASTER CERTIFIED MECHANIC
Hey Sharkatac9,
Here is a guide and article on how to replace your cabin air filter. Some trucks are not quipped though so don't be surprised if you can find it.
Removal and Installation
Cabin air filter is available as an optional dealer-installed kit. Cabin air filter installation instructions are included with the kit. If a filter is already installed, it is located under the right side of the instrument panel in the HVAC housing. Trim panel may have to be removed to gain access to filter. See Fig. 1.
Please let us know happens so it will help others.
SPONSORED LINKS
Saturday, October 3rd, 2020 AT 10:51 AM
JOHN COOK2
MEMBER
1 POST
2003 FORD F-150
5.4L
V8
4WD
AUTOMATIC
117,467 MILES
Very little air from vents. My truck is the Lariat model.
Monday, April 19th, 2021 AT 11:07 AM
(Merged)
STEVE W.
MECHANIC
Remove the right hand lower instrument panel insulator. If it has a filter it will be attached there. It was a dealer installed option so it will depend on who ordered the truck if it has one.
Hello, Im having a hard time replacing my cabin air filter. 2002 F150 Xlt Supercab. To my knowledge it is behind the glove box. I removed the bottom cover, and i'm lost from there. Thanks
(Merged)
MECHANIC
CABIN AIR FILTER
Removal & Installation
Image (Click to make bigger)
SPONSORED LINKS
(Merged)
JEFFCAPP
MEMBER
1 POST
2001 FORD F-150
6 CYL
2WD
AUTOMATIC
83,000 MILES
Does the 2001 F150 have an cabin air filter? If so where is it located.
(Merged)
MERLIN2021
MECHANIC
Not installed on all vehicles! Optional, can be installed on any F150.
(Merged)
ARMANDOZ
MEMBER
1 POST
1999 FORD F-150
Where is it located ?
(Merged)
MECHANIC
(Merged)
DEBORAH7780
MEMBER
1 POST
1998 FORD F-150
V8
2WD
AUTOMATIC
160,000 MILES
Where is the air cabin filter located on a 1998 Ford f150?
(Merged)
MECHANIC
Note: Not all of these vehicles were equipped with a Cabin Air Filter. Only vehicles with a filter cover in the location shown have a Cabin Air Filter
(Merged)
MIKESCH
MEMBER
1 POST
1998 FORD F-150
V8
2WD
AUTOMATIC
13,100 MILES
Does my truck have a cabin air filter and if so where is it located and how can I change it?
SPONSORED LINKS
(Merged)
BLUELIGHTNIN6
MECHANIC
(Merged)
USAEAGLE6
MEMBER
1 POST
1998 FORD F-150
V8
2WD
AUTOMATIC
235,000 MILES
The A/C and heater are working. I can hear the blower. However, there is very little air coming out of the panel. Is this a bad switch [a/c, max, panel, etc] or is there another switch someplace that routes the air? In other words, everything seems to be fine, but little air comes out the vents outward.
Tuesday, April 20th, 2021 AT 9:47 AM
(Merged)
2CARPRO JACK
MECHANIC
If the blower speeds are aall working and the vents are ok, you may have a cabin filter that is plugged up.It was a dealer installed option on those trucks.Here is a pic of where it is located,(under the dash on pass side)
