Window not working correctly?
MACGYVER52
  • 2010 FORD EXPEDITION
  • 5.4L
  • V8
  • 4WD
  • 107,000 MILES
The cable on the passenger side broke that pulls it back up, how do I fix it as I can not see where it attaches
Saturday, August 30th, 2014 AT 6:13 PM
  • 108,192 POSTS
The cable needs replaced which is the window regulator here is a video to show you how
https://youtu.be/oNxstjcA25k
Saturday, August 30th, 2014 AT 7:29 PM
MACGYVER52
Yep, did it works great nice site and video btw.
Sunday, August 31st, 2014 AT 3:41 AM
GREYFOX503
  • 2008 FORD EXPEDITION
  • V8
  • 43,000 MILES
How do I change out drivers side window regulator, do you have pictures of it?
Tuesday, July 21st, 2020 AT 5:36 PM (Merged)
2CARPRO JACK
  • 11,533 POSTS
Sorry for the delay, somehow your post got shuffled to the bottom of the list. First remove the inner door panel (see pic for attaching points)
https://www.2carpros.com/forum/automotive_pictures/1639_ford_1_1.jpg
Then remove the speaker and inner door handle from door. Unbolt the window clamps on the regulator (see pic)
https://www.2carpros.com/forum/automotive_pictures/1639_ford2_1.png
The regulator is a large assembly, so you will have to unclip all wiring from it and work it out from behind the harness.Unbolt and remove regulator (see pic for reg mounting bolts)
https://www.2carpros.com/forum/automotive_pictures/1639_ford_3_1.png
DLS57
  • 18,000 MILES
I just installed new regulator, now in the process of putting back together and the window is not where it belongs. Maybe not lined up?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,904 POSTS
The window will set itself. Put it up as high or as low as it will go. Then disconnect the the battery and let is sit for 20 minutes, then reconnect the battery this should reset the initialization.
Also make sure the new regulator is not bound up. I has seem new ones out of the box defective.
Please let me know if you need anything else to get the problem fixed.
Best, Ken
2CP-ARCHIVES
  • 4,542 POSTS
  • 2007 FORD EXPEDITION
  • 12,000 MILES
Replaced passenger front window regulator. Replaced driver and passenger front window motors. Al so replaced drivers side master switch. When u press the window switch it just makes a humming sound. Used all motorcraft parts. Checked all fuses. Out of ideas.
WRENCHTECH
  • 20,757 POSTS
Did you replace all those parts trying to correct the same problem?
What window are you having a problem with and from which switches?
Is the window trying at all. What type of noise is it making?
IZZI131
  • 79,000 MILES
My motor burned out and I want to roll up the window manually
Tuesday, July 21st, 2020 AT 5:37 PM (Merged)
  • 31,938 POSTS
You will have to remove the door trim, disconnect the window motor and push the window up and chock it with a length of timber.
SATURNTECH9
  • 30,870 POSTS
Just to add to this one you could try removing the inner door panel and tapping on the window motor with a hammer while rolling the window up. Sometimes you can get the windows up that way.
IZZI131
If the window regulator cables are sheering would that stop the window from moving up and down
MAFREIRE
  • 2005 FORD EXPEDITION
  • 108,000 MILES
On my 2005 expeition, turning on lights or turning on ac triggers rear window latch and at the time if feels like the battery is being drained. Sometimes it even stalls.
HMAC300
  • 48,601 POSTS
Both the headlight and doorlocks which is lift gate use the same ground behind right kick panel. That can be loose or a bad ground to the body altogether from the battery. They also use the same fuse.
FIXITMR
  • 9,990 POSTS
Could be a fusebox, BCM, or wiring issue. Anything done to vehicle just prior to this starting to occur?
MAFREIRE
Thanks for the help gentlemen. The question posed by fixitmr has 2 answers. The battery was replaced 2 weeks ago and the ac evaporator was replaced 8 days before this started happening. The vehicle also needs a new compressor as it is only running at 50% and the intial back window latch trigger issue initially began when I turned on the ac and the compressor kicked in. It has now moved on to the door locks and the head lights.
IRVY76
  • 2006 FORD EXPEDITION
  • V8
  • 4WD
  • 85,000 MILES
My drivers side window will go down like normal but will not go up or creep up very slow and stop before its all the way up? What does this problem sound like? Thank you
  • 108,192 POSTS
It sounds like a bad switch. Check voltage to the motor and see if it is less than 12 volts when you put it in the up position.
Let me know what you find.
GHARDUBY
  • 2004 FORD EXPEDITION
  • 70,000 MILES
The window rolls down finw but rolls up very slowly. In the winter it seems like it is not going to make it.
SATURNTECH9
  • 30,870 POSTS
You have a weak window motor or binding up window glass. You will have to remove the inner door panel unhook the window glass from the window regulator and see if the window goes up without binding by hand. Its most likely a weak window motor though.
