1998 Ford Escort timing belt
FEATHERFARM
  • 1998 FORD ESCORT
  • 4 CYL
  • FWD
  • 98,000 MILES
Hi! The timing belt broke on my daughters 989 ford escort ZX2. Can you give me a ball park figure on cost to fix it?
Do you
have the same problem?
Saturday, November 7th, 2009 AT 11:16 AM
BLUELIGHTNIN6
  • EXPERT
Is this the SOHC or DOHC engine?
There is possibility of internal damage to engine since the timing belt broke during operation. Valves could have been bent along with other internal parts. If so, the repair cost will be much higher than simply replacing the timing belt.
Saturday, November 7th, 2009 AT 5:06 PM
STEVE LV
There are two types of engines that use timing belts. They are described as: "Interference Engines" and "Non-interference Engines" The difference lies in the proximity between the valves and the pistons. On an interference engine, if the timing belt slips even one notch, the piston can crash into an open valve causing serious engine damage by bending valves and breaking pistons. Non-interference engines will usually not self destruct, but in either case if the belt fails, the engine will immediately shut down leaving you stranded.
I personally changed my timing belt on my 98 Escort. It was a pain but it saved me money!
Here's a list of engines that would be damaged by a timing belt failure while driving. Not sure if it's complete. But may be a good start.
1981-85 1.6L Escort, EXP
1981-83 1.6L LN7, Lynx
1984-85 2.0L Escort, Tempo
1993-95 2.0L Probe
1986-88 2.0L Ranger
1984-87 2.0L Lynx, Topaz Diesel
1985 2.2L Ranger
1989-92 2.2L Probe
1986-88 2.3L Ranger
1986-87 2.3L Diesel Ranger
1991-98 4.6L Crown Victoria
Monday, December 7th, 2009 AT 1:12 PM
Recommended Guides
