I poured one bottle of dry gas into the tank. Yes the fuel pump sounds strong. Just replaced the distributor plugs and wires also. Yes it smelled like fuel.
Wednesday, November 20th, 2019 AT 2:29 AM
MECHANIC
The dry gas will have little or no effect.
You would need to drain the entire tank and add fresh fuel.
That is if the fuel is the issue.
Wednesday, November 20th, 2019 AT 2:39 AM
PARKS PAUL
MEMBER
How is that to be done? Is there any other solutions?
Wednesday, November 20th, 2019 AT 5:26 PM
MECHANIC
You would need a siphon to remove the bad fuel from the tank. Then you can add the new fuel.
No, there is no other solution.
This is assuming that the fuel is the issue.
Wednesday, November 20th, 2019 AT 5:30 PM
PARKS PAUL
MEMBER
The quickest way to siphion all of the fuel from a tank that has been topped off would be a hose going into the fuller neck?
Wednesday, November 20th, 2019 AT 5:42 PM
MECHANIC
Correct.
Wednesday, November 20th, 2019 AT 5:58 PM
PARKS PAUL
MEMBER
Would it be faster to disconnect the fuel filter and keep on priming the pump?
Wednesday, November 20th, 2019 AT 6:19 PM
MECHANIC
It only runs for 2 seconds at a time. It would take a long time.
