Engine stalling, looses power, then hard to start
CLEVENHAGENJS
  • 25 POSTS
Hi, Still needing some help, can you help me resolve some more issues with this?
Thursday, May 19th, 2016 AT 7:19 PM
CLEVENHAGENJS
  • 25 POSTS
STILL- Having the same issues as mentioned in the above 2 pages.
1- Is there a easy way to check to see if the crank Shaft Sensor may be causing this issue of stalling? Seems to happen when the car starts from a cold start in the AM until it warms up-
Thursday, May 19th, 2016 AT 7:28 PM
KHLOW2008
  • 41,814 POSTS
Usually if the crank sensor is causing the problem, it would throw a code. However if you have a scan tool plugged in, you can monitor the crank sensor pulse.
Sunday, July 3rd, 2016 AT 7:52 AM
