Engine coolant temperature sensor location
BCW19811
  • 2016 FORD F-150
  • 5.0L
  • V8
  • 4WD
  • 60,200 MILES
I have pulled the code, P1289 and got the replacement part but need to figure out where it is located.
Do you
have the same problem?
Monday, September 30th, 2019 AT 3:39 PM
JIS001
  • EXPERT
That code indicates you overheated. The first thing you need to do is check for a low coolant along with a coolant leak. Also make sure you have the correct coolant. Send a picture of the expansion level to see what's in there now. But please do a pressure leak test. Here is a link on how to do one:
https://www.2carpros.com/articles/radiator-pressure-test
Monday, September 30th, 2019 AT 4:47 PM
BCW19811
My coolant is not low and I don t have a leak nor was my engine overheating when it shut down and went into safety mode. I just need the location of the sensor.
Monday, September 30th, 2019 AT 4:52 PM
BCW19811
It said warning excessive coolant temperature but it wasn t hot. The engine was cold when it came on.
Monday, September 30th, 2019 AT 4:56 PM
BCW19811
The part is a cylinder head temperature sensor.
Monday, September 30th, 2019 AT 5:00 PM
JIS001
  • EXPERT
Removal
NOTE: Removal steps in this procedure may contain installation details.
Remove the RH fender splash shield.
Refer to: Fender Splash Shield (501-02 Front End Body Panels, Removal and Installation).
NOTE: Do not reuse the CHT sensor, install a new sensor.
Disconnect the CHT sensor electrical connector.
Remove and discard the CHT sensor.
Torque : 97 lb. In (11 Nm)
Monday, September 30th, 2019 AT 10:22 PM
BCW19811
Can you post a link to the fender splash guard removal? I have searched the site and cannot find it. Thanks
Saturday, October 5th, 2019 AT 6:39 AM
JIS001
  • EXPERT
Here you go. Good luck with the repair.
Saturday, October 5th, 2019 AT 7:42 AM
BCW19811
Do the clips in the first diagram unscrew or do they pop out? Also are they reusable or do I need replacements?
Saturday, October 5th, 2019 AT 8:07 AM
JIS001
  • EXPERT
All the plastic clips pop out.
Saturday, October 5th, 2019 AT 9:11 AM
BCW19811
Problem solved. The part was easy to swap out. Took about 30 minutes from start to finish. I think I wasted more time looking for my ratchet. Thanks for the help.
Sunday, October 6th, 2019 AT 5:20 PM
Recommended Guides
