Lack of power and code P1890
JODENE NOACH
  • 2008 HONDA FIT
  • 1.3L
  • 65,000 MILES
"Hi there, it seems like the car has no power. Drives okay when first start or cold. I have an error code P1890 CVT speed control current control system when I diagnosed the car. Please could you help? Does the whole transmission need replacing or part replacement? Or simply an oil change? Much appreciated.
Tuesday, April 17th, 2018 AT 2:35 AM
  • 52,797 POSTS
Did you ever get a chance to verify this code number? I do not see it at all.
Does the transmission work correctly? Are you having an issue with shifting?
This code is for transmission shifting errors.
You will need an advanced scan tool to check this code. I posted the description below for you to view.
Problem in Shift Control System
NOTE: Before you troubleshoot, record all freeze data and any on-board snapshot, and review General Troubleshooting Information.
1. Clear the DTC with the HDS.
2. Test-drive the vehicle for several minutes in D through all five gears, then slow down to a stop.
3. Turn the ignition switch to LOCK (0), and repeat the test-drive in step 2.
4. Check for other DTCs indicated simultaneous with DTC P1780.
NOTE: DTC P1780 means there is one or more A/T DTCs about the shift control system.
Are there other DTCs?
YES - Troubleshoot the problem indicated by the DTC.
NO - Go to step 5.
5. Update the A/T software in the PCM if it does not have the latest software, or substitute a known-good PCM.
6. Test-drive the vehicle for several minutes in D through all five gears, then slow down to a stop.
7. Turn the ignition switch to LOCK (0), and repeat the test-drive in step 6.
8. Check for DTC(s) in the DTCs/Freeze Data in A/T Mode Menu with the HDS.
Is DTC P 1780 indicated?
YES - If the PCM was updated, substitute a known-good PCM, then recheck. If the PCM was substituted, go to step 1.
NO - Go to step 9.
9. Monitor the OBD status for P1780 in the DTCs/Freeze Data in A/T Mode Menu for a pass/fail.
Does the HDS indicate PASSED?
YES - If the PCM was updated, troubleshooting is complete. If the PCM was substituted, replace the original PCM. If any other DTCs were indicated on step 8, go to the indicated DTC's troubleshooting.
NO - Check for poor connections and loose terminals at the PCM. If the PCM was updated, substitute a known-good PCM, then recheck. If the PCM was substituted, go to step 1. If the HDS indicates NOT COMPLETED, return to step 6 and recheck.
Monday, September 14th, 2020 AT 3:30 PM
ZAYAR
  • 2008 HONDA FIT
  • 160,000 MILES
When driving engine rpm is 2,500-3,000 my select lever press but car speed is 60 km. This in time my move gear position change is occur vibrate feel my car. My made change gearbox but this error is sometime occur. But this error is occur little minute. Return normal condition is little minute. My made change gear oil/maf sensor and air throttle clean and EGR valve cleaning.
Tuesday, September 15th, 2020 AT 9:52 AM (Merged)
  • 108,310 POSTS
Welcome to 2CarPros.
Is the check engine light on and staying on or flashing when the engine is running?
https://www.2carpros.com/articles/check-engine-light-top-ten-reasons
If it stays on, has the computer been scanned to retrieve diagnostic trouble codes?
Has the fuel pressure been tested or has anyone checked for a partial plugging of the catalytic converter? If not, have that done.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
ZAYAR
Engine check light is not open this position. My check connect computer but not occur another problem trouble code.
  • 108,310 POSTS
If there are no codes, then it becomes a test procedure. Have you checked fuel pressure? Have you checked to see if anything is plugging the catalytic converter?
ZAYAR
I do fuel filters change and fuel pump pressure check I see good condition. Exhaust system is visible check is good condition.
WALLACE
  • 2007 HONDA FIT
  • 4 CYL
  • FWD
  • 150,000 MILES
Started losing power so I installed coil packs and new plugs. Ran good for 10 miles then it started back firing and lost all power and now it won't start.
HMAC300
  • 48,601 POSTS
Scan for codes and check fuel pressure first. If ok check for timing belt jump or broken
  • 108,310 POSTS
Have you tried removing a pre catalytic converter oxygen sensor to see if it changes? The exhaust may appear to be good, but internally, there could be issues.
WALLACE
Thank you very much.
