2004 Dodge Ram Won't turn left
TOMB175
  • 2004 DODGE RAM
  • 6 CYL
  • 4WD
  • 178,000 MILES
I took off from a stop, making a right turn. When I turned the wheel back to straighten it up it had some resistance. I then wiggled the wheel back and forth as I was driving, no issues except there it was a little titer. I went around a corner same thing, when straitening up the wheel, resistance. When I stop to turn on to my road, I couldn't turn the wheel left at all. I had to go up the road and turn right in to a lot. Sitting in the lot I tried to turn the steering wheel left it wouldn't move but it would move to the right. I got out looked under the hood and the truck nothing looked out of the norm. After I got back in the truck I could turn the wheel to the left.
Friday, May 29th, 2009 AT 8:28 AM
CARADIODOC
  • 34,467 POSTS
Put it into 4wd and try turning while driving slowly. If it forces the steering wheel back to center so hard you can't hold it, suspect a tight front outer universal joint.
Caradiodoc
Friday, June 5th, 2009 AT 2:57 AM
