1999 Dodge Durango Change heater core
MIGUELALEY
  • 1999 DODGE DURANGO
  • V8
  • 4WD
  • 150,000 MILES
It is hard to change the heater core? And how you can change?
Do you
have the same problem?
Monday, April 6th, 2009 AT 1:30 PM
BLUELIGHTNIN6
  • EXPERT
REMOVAL/INSTALLATION:
Disconnect the battery negative cable.
Remove the instrument panel from the vehicle.
If equipped with air conditioning, recover the refrigerant.
Disconnect the liquid line refrigerant line fitting from the evaporator inlet tube.
Ram: remove the accumulator.
Disconnect the accumulator inlet tube.
Drain the cooling system.
Disconnect the heater hoses from the heater core tubes.
Ram: remove the powertrain control module from the dash panel. Disconnecting wiring is not necessary.
Remove the four nuts from the heater-A/C mounting studs on the engine compartment side of the dash panel.
Remove the nut(s) that secure(s) the heater-A/C housing mounting brace to the stud(s) on the passenger compartment side of the dash board.
Pull the housing rearward far enough for the mounting studs and evaporator condensate drain tube to clear the dash panel holes.
Remove the housing from the vehicle.
Lift the heater core out of the housing.
Installation is the reverse of removal.
http://www.2carpros.com/forum/automotive_pictures/261618_1_28.jpg
Thanks for using 2CarPros.com!
Monday, April 6th, 2009 AT 3:10 PM
Recommended Guides
